Wheel direction ????
Old Feb 19, 2002 | 08:23 PM
Jack78's Avatar
Jack78
Default Wheel direction ????
I have the "sawblade" factory wheels on my recently acquired '93. I bought new tires almost immediately upon getting it home and it just hit me - the "sawblades" aren't turning in the same direction, so I assume one pair of wheels is mounted opposite of where it belongs...... two questions:
1. Which way SHOULD they go? ( a pic would be greatly appreciated).
2. I've put about 400 miles on these tires. Assuming say the front ones are reversed, if I just flip them (left for right, right for left) will the fact that they've been driven a couple of hundred miles significantly impact my tread wear? Thanks....
Old Feb 19, 2002 | 08:25 PM
scorp508's Avatar
scorp508
Default Re: Wheel direction ???? (Jack78)
In your sig pic, the rear left rim is going the right way. :)
Old Feb 19, 2002 | 08:44 PM
8388's Avatar
8388
St. Jude Donor '14
Default Re: Wheel direction ???? (scorp508)
Most factory wheels are designed to pump the air from the inside of the wheel to the outside, looking at the direction the blades spin will tell you. One of the drawbacks is all that brake dust that winds up on the outside of the wheel. They are designed that way in order to vent the brakes while the car is moving forward.
Old Feb 19, 2002 | 11:34 PM
BBA's Avatar
BBA
Pull a wheel off and look at it's backside. There is stamped in the casting of the wheel itself exactly which side of the car it is made to be on.
Old Feb 20, 2002 | 11:58 PM
Rick Williams's Avatar
Rick Williams
The tires and wheels should be unidirectional..at least mine are..the tires and wheels both have direction indicators on them.. Your picture shows the left rear wheel appears correct..
My wheels are 95s. So I don't know about 93..
Old Feb 21, 2002 | 10:04 AM
ittlfly's Avatar
ittlfly
ditto...my 1992 wheels are stamped on the inside as to location side of car.
Old Feb 21, 2002 | 01:37 PM
OURRUBY's Avatar
OURRUBY
Spending his inheritance
Cruise-In VIII Veteran
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Your left rear wheels is correct, so if you have directional tires on the wheels that are on wrong, you'll have to have them remounted.
Old Feb 21, 2002 | 02:06 PM
BlueDemon's Avatar
BlueDemon
Default Re: Wheel direction ???? (OURRUBY)
Make sure the tire is going in the right direction as well. You will probably need them remounted more than likely.
Old Feb 21, 2002 | 10:41 PM
Jack78's Avatar
Jack78
Default Re: Wheel direction ???? (BlueDemon)
Thanks guys - I guys I'll have the fronts remounted - the rears are correct.......
Old Feb 21, 2002 | 10:43 PM
RadPolo96's Avatar
RadPolo96
Look at my pic :cheers:
To Wheel direction ????
