'92 alignment/pulling problem
Old Sep 8, 2009 | 12:53 PM
BlackbirdZ07's Avatar
BlackbirdZ07
Default '92 alignment/pulling problem
I just had some front end work done to my '92- new upper and lower control arms, new steering rack, and new outer tie rod ends. Before the work the car drove great- no pulling to either side.
After alignment at a supposedly competent shop, the car pulled to the right, not terribly but it was noticeable. Also, when driving staight the steering wheel was slightly off to the left. They showed me the computer print out of the alignment specs and the car was perfectly in alignment. They said it may be a tire problem (although it didn't pull before the front end work with the same tires) so they dismounted and switched the front tires. As I expected- no change- car still pulled right.
They finally set the caster (on the left side I believe) way out of specification to stop it from pulling. It feels much better but still pulls right a little bit at high speed.
My questions: Why would it pull to the right after the front end work if it's perfectly in alignment? Does setting the caster far out of spec do any harm? Should I take it to another shop?
Old Sep 8, 2009 | 01:00 PM
engle1147's Avatar
engle1147
Broken belts in the tires could cause the pull. Their machine could be out of wack and their version of "correctly aligned" could be off. Find another shop and get it checked/aligned again....get before and after print outs.
Old Sep 8, 2009 | 04:02 PM
tblt44's Avatar
tblt44
The person doing it could be the problem.
I had the same problem with a van till I took it to chevy for an alignment
Old Sep 8, 2009 | 04:11 PM
NMsharkracer's Avatar
NMsharkracer
From: Formerly from the Great White North but now residing in the Desert Southwest NM (The Land of Dis-Enchantment?)
Ryan
Take it to Firestone on 448 behind Coronado. Jim Allen runs the place and is a Corvette guy. Have Cyrus do the alignment, he does the Vettes. Get a before and after print out and if it's signicantly off make the original shop give you a refund. Jack
Old Sep 8, 2009 | 04:33 PM
BlackbirdZ07
Originally Posted by NMsharkracer
Ryan
That's who did the alignment. I wasn't aware that Jim was at the Coronado Firestone, but he's now at the one on Coors near Cottonwood mall, which is where I took the car. I don't know who actually did the alignment, but Cyrus sounds familiar. I dealt with Jim the whole time, and while he did what he could, it was clear he didn't know what was happening with the car. His conclusion was that the alignment was perfect so the pulling was caused by a tire problem (even though it didn't do it before the front end work and swapping the front tires didn't change it) or the new bushings in the control arms aren't seated properly yet. His solution was to set the caster way out of spec to correct the pulling.
I've always gone to Chet's Wheel Alignment because they have a great reputation, and I think I'll have to spend more money and take the car there to find out what the problem is.
Thanks to everyone!
Old Sep 8, 2009 | 05:18 PM
Churchkey's Avatar
Churchkey
As advised find another alignment shop.
Normally both front wheels should be set differently from each other to compensate for crown of the road.
The vehicle needs 1/4 degree less caster in the left front as well as 1/4 degree more camber in the left front. In some situations such as front cross member sag due to age, collision damage or worn components the alignment may not meet factory specs however a good alignment specialist can compensate & make the vehicle track straight.
A vehicle will pull to the side that has less caster than the opposite side.
A vehicle will pull to the side that has more camber than the opposite side.
The steering wheel should be centered when the toe in is set. Since your wheel is off center the correct toe in may have been set however the procedure used was incorrect.
Vettes can have the thrust angle adjusted which will effect straight ahead tracking. This procedure involves rear wheel alignment. You did not mention rear alignment, your problem is more than likely incorrect front end adjustment by an incompetent tech or faulty alignment equipment.
Old Sep 8, 2009 | 07:38 PM
BlackbirdZ07
Thanks Churchkey, good information.
It's going to a good alignment shop tomorrow so I'll see what they say, and post an update when I know.
Old Sep 8, 2009 | 08:02 PM
NMsharkracer
I meant Cottonwood...man, if they messed it up there's very little hope in ABQ. Chet's has a good reputation, but they wouldn't touch my race car.
Churchkey's info is right on. I'd make sure they do a complete four wheel alignment. If you've made mods only to the front and those mods caused some geometry change the rear alignment could have some effect. And I'd go back and smack Cyrus figuratively speaking. Get a before printout incase there is a major fault in their settings.
To '92 alignment/pulling problem
