91 Service Engine Soon light code 43
Old Sep 9, 2009 | 10:56 AM
gevans's Avatar
gevans
Default 91 Service Engine Soon light code 43
I have a 91 vette with the SES light that comes on for about 2-5 minutes, when first starting up, then goes out. Car sputters like it has bad fuel when I get on it (but it's not bad gas). I read the codes and it had a 12 and 43. Everything under the hood looks normal. Had the fuel injectors, gas filter, plugs and wires changed @ 3 months ago. Read on the forum that a code 43 is usually a knock sensor - will the knock sensor make the car sputter as well? Thanks!
Old Sep 9, 2009 | 11:07 AM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
Not sure if a bad knock sensor would cause sputtering. Does it run OK otherwise? Have you checked the throttle position sensor? How many miles on the car?
Old Sep 9, 2009 | 11:18 AM
gevans's Avatar
gevans
Thanks for the quick reply! The car runs okay other than the sputter. I have 42k miles. Haven't checked throttle position sensor - Don't know how or what to look for on that.
Old Sep 9, 2009 | 12:40 PM
93_vette's Avatar
93_vette
At least your's threw a code....
The knock sensor will cause hesitation. I'm going through the same thing right now on my 93. The FSM manual says to unplug both knock sensors and see if that helps. If it does, then one or both are bad. here's the check for them. Using a digital multimeter, set it to two volts and place the positive on the terminal of the knock sensor and ground to chassis. tap on the exhaust or engine block and see if the voltage jumps, if not...replace knock sensor, if so, check/replace prom or ecm.
Oh by the way, to remove the connector from the knock sensor, squeeze the sides and pull and it should pop off. I spent 10 min. trying to figure that one out. Depending on your fingers and hands, you may be able to get the connector off without removing the heat shields, but they are only held on by a couple of 11mm nuts.
I'm waiting for my k.s. now from zip corvettes.
Good luck.
Old Sep 9, 2009 | 12:45 PM
gevans's Avatar
gevans
Thanks a lot for the info! I appreciate it!
Old Sep 9, 2009 | 01:24 PM
MK 82's Avatar
MK 82
The knock sensor doesn't cause anything. It's function is to sense detonation. Depending upon the severity, the ECM will retard timing until the "knocks" are at an acceptable level.
The act of retarding the spark may cause the symptoms you describe.
Are you running Regular or Premium? You say it is not the fuel. How do you know? It is easy to get a "bad" tankful.
Check the base timing. It should be a 6 BTDC. Be sure to disconnect the EST wire between the brake booster and the rear of the engine. Disconnect the neg batt terminal for 30 secs to clear the code cause by disconnecting the EST.
Let us know what you find.
Old Sep 11, 2009 | 10:12 AM
gevans's Avatar
gevans
idle is 6 btdc. I know it's the gas because I'm on my third tank since I've had the problem. Always have filled up at the same high service area gas station with 93 octane.
Old Sep 15, 2009 | 08:03 PM
93_vette's Avatar
93_vette
did you fix your sputtering? For me, my K.S. was the problem, although mine never threw a code, it only acted like it was going to throw up a times.
Anyway I replaced the K.S. today and it runs great. Hope you got 'er going.
Marlon
Old Sep 24, 2009 | 07:35 AM
gevans's Avatar
gevans
It was the Knock Sensor the threw the SES light! Light is out - I haven't driven it much since replacing the sensor so don't know if it's still sputtering - hasn't sputtered since taking it out for a quick drive. Thanks all for your help!
To 91 Service Engine Soon light code 43
