Power antenna is not going back down
My antenna is not going up and down any longer on our 1991. It's in the up position. The fuse is good. The motor is motoring but not making it go back down.
I called Corvette America and they have a mast repair kit. My questions are:
Has anyone out there used these mast repair kits to correct the problem, if so what level of time am I going to be looking at? It looks like the exhaust may have to be lowered a bit to get to the antenna.
Am I in the ball park as to fixing the problem or am I looking at it from the wrong angle and maybe there is an easier solution that I'm overlooking?
Danny
http://cgi.ebay.com/ebaymotors/88-89...Q5fAccessories
I am going to try getting it fixed with the kit and if that doesn't do it then I suppose the next step will be a complete new antenna assembly...choke..$240.00 from the local Chevrolet dealer.
There are some very useful tips off the forum regarding getting this fixed and I do appreciate all the help from guys like yourself.
Danny
Date Published: 2001-06-08
Submitter's Name: Julian Shipp
Email Address: julianshipp@journalist.com
Corvetteforum.com Member Alias: onedef92
Due to several e-mail inquiries, here are the instructions for removing the power antenna motor for service BEFORE installing a new antenna mast on 1992-1996 Corvettes.
Many owners (myself included) have tried in vain to simply install a new antenna ribbon without inspecting the motor first for broken sections of the old one.
The usual result is an antenna that won't fully raise or retract, even though the motor works fine. Hopefully, this tech tip will save you from this aggravation.
I'm not familiar with the design for 1984 - 1991 models, but the process should be similar.
I also understand from other Forum members that the antenna motor design apparently changed in 1995 from housings that are screwed together to housings that are glued together.
If this is the case, it may be possible to pry the assembly apart for inspection. Anyway, here goes:
The power antenna motor is visible from underneath the vehicle if you lie on your back and look at it from the driver's side of your car.
Please protect your eyes from dirt and other particles that may fall from your fender well while you are working! Some Forum members opted to place their vehicles on jack stands and remove the driver's side rear wheel first, but I have long arms and did not have to do so.
1. Disconnect the negative battery terminal. Note the way the motor is oriented as installation is the exact order of removal. The motor is held in place on its mounting bracket by two screws. Use either a socket wrench with an extension or a screwdriver with a ratchet to remove the bolts. Note that one of the bolts has a ground/power wire for the antenna.
2. With these two bolts loosened, you will be able to pull the antenna down toward you enough to loosen the antenna gain and positive power wires located at the top of the unit. With all these wires removed, the entire assembly can be pulled down for access while leaving the wire that lead inside the motor housing intact.
3. With the unit now in your hand, roll up the black rubber sleeve that protects the unit from moisture, dirt, etc. There are approximately four Phillips head screws that hold the cover on the motor housing. Remove these screws. Also, remove the center nut that holds the antenna flywheel in place.
With the cover off, you will see the flywheel and the main gear that raises and lowers the nylon antenna ribbon. You will also more than likely find bits or long sections of your OLD ribbon. Remove them.
4. Now is the time to lubricate the main gear and flywheel with either Vaseline or white lithium grease to ensure years of trouble-free operation with your new ribbon.
5. Replace the flywheel (noting its direction) and screw the cover back into place. Re-install the antenna, connect all the wiring and hook your battery back up. Turn on the ignition and radio and listen to see if the motor runs. If it does, you are ready to install your new mast. Just follow the directions that came with it and you should be in great shape.
6. Above all, be patient. It took me about four hours the first time I did this because I thought you had to remove the license plate, tail lamps and back up lamps to get to the motor. You don't! I could now do the whole thing again in 30 to 40 minutes (but hopefully not on MY LT-1 any time soon!) Good luck and keep on waving!
Any help is greatly appreciated.
Matt
