Self adjust rockers or not?
Old Sep 15, 2009 | 11:04 PM
Alex Annapolis's Avatar
Alex Annapolis
Default Self adjust rockers or not?
Ok I know this topic is talked about A LOT but please bear with me, I did a serch and after an hour of reading was still confused.
I own a stock 90 6-spd. It has just over 100k on the odometer and runs good. I just want to add a little more power so I can at least hang with the newer mustangs. Ive read roller rockers and exhaust are the easiest way to get some quick HP. I use this car daily by the way.
My questions are why do some recommend going with the 1.5 for intake and others the 1.6?
Also, ive heard that the self aligning are the way to go when others say to use the guide plates and hardened pushrods, which is best for a stock car?
Old Sep 15, 2009 | 11:19 PM
JackDidley's Avatar
JackDidley
You need self aligning for a 90. No such thing as self adjusting. I would do intake and exhaust. I see no point in changing guide plates and all that. You may want to install new springs while you are at it but even that is optional. The increase in lift will get you some easy horsepower but its not enough to just automatically kill the springs. This is really one of the easy mods that work.
Old Sep 15, 2009 | 11:25 PM
Alex Annapolis
So you would still use the guide plates in this setup? I thought I read not to use them with the self aligning
Old Sep 16, 2009 | 12:22 AM
89onlyZ51's Avatar
89onlyZ51
The stock guideplates and pushrods on a '90 are not hardened, and a "self-aligning" rocker keeps the rocker tip located on the valvestem. It's 6 of one 1/2 a dozen the other. You can also get non-self-aligning rockers and then also buy hardened pushrods and guideplates to keep the rocker located correctly on the valvestem.
1.6's just give you about 7% more lift from the same cam and a touch more duration, too. It's a lot easier to change rockers than a cam; that's why 1.6 rockers are a popular mod.
Old Sep 16, 2009 | 12:23 AM
rodj's Avatar
rodj
The "guide" plates you see on your engine are not true guide plates; only there to help assembly at the factory.
If you run self aligning rockers you keep the factory plates.
If you go to non self aligning rockers you need to install "proper" guide plates and harderened pushrods
Old Sep 16, 2009 | 12:32 AM
Alex Annapolis
what do you guys think of the summit racing aluminum rockers? They are self aliging, narrow width and not too expensive. However, I will spend more if their going to last much longer
Old Sep 16, 2009 | 12:41 AM
Pwnage1337's Avatar
Pwnage1337
I don't believe summit to sell junk, so I would trust them.
Old Sep 16, 2009 | 05:37 AM
ndanl's Avatar
ndanl
how do they self adjust ?
Old Sep 16, 2009 | 10:54 AM
CFI-EFI's Avatar
CFI-EFI
They don't. Hydraulic lifters automatically, hydraulically, maintain zero lash, once the installer sets the preload, properly. The preload is set by moving the fulcrum of the rocker arm. The same as adjusting the valve lash for a mechanical lifter cam.
RACE ON!!!
Old Sep 16, 2009 | 10:58 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
RACE ON!!!
Good to see you back
Old Sep 16, 2009 | 11:02 AM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
I believe these are the blue made in China ones, don't buy them. I tried installing a set once and the machining was off on some of them and they cocked the push rods off to one side, rubbing against the guide plates. If you want a set I can sell them to you real cheap. Spend a little more and get a quality product.
Old Sep 16, 2009 | 11:20 AM
CFI-EFI's Avatar
CFI-EFI
Thank you.
RACE ON!!!
Old Sep 16, 2009 | 09:54 PM
Alex Annapolis
thanks guys
I think im going to go with the comp cams pro mag. just not looking forward to grinding down the bolt sleeves. Im thiking of just buying new valve covers but their not as cheap as i thought.
Hey still never got an answer on 1.5 vs 1.6 for the intake?
Old Sep 17, 2009 | 11:13 AM
CFI-EFI's Avatar
CFI-EFI
The change in rocker ratio will increase the valve lift at any point the valve is off seat. Valve lift equals cam lift multiplied by the rocker ratio. To determine the change in valve lift, divide the present valve lift by 1.5 to determine the cam lift and then multiple as above. Typically, changing to 1.6:1 rockers from 1.5:1 will result in an increase of valve lift somewhere around .030". The seat to seat duration will not change one ounce. The rollers will add little to no additional power, over the stock ball fulcrum. All told, the rocker arm swap could give you a power increase of 10 - 15 HP.
RACE ON!!!
Old Sep 17, 2009 | 12:07 PM
engle1147's Avatar
engle1147
I felt these things were just assembly plates too but Summit sells and advertises these: http://www.summitracing.com/parts/NAL-3973418/I ordered a set of these awhile back since they are advertised as "hardened" guide plates and I was going to run non self aligning rockers. These things are identical (shape/size, stamp marks & and hardened coating material) to what came on my '89 from the factory. with non self aligning....you will need "hardened" pushrods.
Old Sep 17, 2009 | 01:03 PM
ndanl's Avatar
ndanl
Originally Posted by engle1147
I felt these things were just assembly plates too but Summit sell and adversites these: http://www.summitracing.com/parts/NAL-3973418/I ordered a set of these awhile back since they are advertised as "hardened" guide plates and I was going to run non self aligning rockers. These thing are identical (shape/size, stamp marks & and hardened coating material)to what came on my '89 from the factory. with non self aligning with you will need "hardened" pushrods.
where is located that part from summit, on the engine ?
Old Sep 17, 2009 | 02:36 PM
turbotim23's Avatar
turbotim23
I always thought 1:5 rockers were the same as stock and you only got the horse power increase by going to the 1:6's. I've heard of people using 1:6 on the intake side and 1:5's on the exhaust but I thought that was only on aluminum heads with pressed in rather than screwed in rocker studs.I think most corvettes are the screwed in type . If I were you I wouldn't do this without also replacing the springs, to close to the edge of what stock springs can handle.Best springs are the comp 26918 beehive springs. time you buy a kit with 26918 springs,retainers,locks you'll have 260.00 into it.the comp pro mag. rockers are apx. 285.00. I really want to do this too but wonder if the over 500.00 cost is worth it for 15- 20 horse power.After all putting about this same money into a gear change for rear would make car much better than just rockers. Do a gear change first! Good Luck Tim
To Self adjust rockers or not?
Old Sep 17, 2009 | 03:15 PM
engle1147's Avatar
engle1147
Old Sep 17, 2009 | 03:35 PM
rickneworleansla's Avatar
rickneworleansla
After adding up the costs like you just did my rocker swap became a cam swap. I figured if I was going to spend all this money why not do the valve train correctly and get a hp increase I could actually feel with the cam swap.
Old Sep 17, 2009 | 06:25 PM
turbotim23's Avatar
turbotim23
With most cams better than stock you come right back to needing better gears and a torque converter to better get car rpm's to where the cam makes power.Buy too big a cam and not do these you are just wasting your money and you might end up with a car not very streetable or one that doesn't make near the power it should. Comp cams has a few cams that don't require gears and converter change but then you don't get as much h.p. increase either. The comp cams 502 is I beleive one of these. It requires headers, Intake flow improvements,and computer reprograming.Everything is interconected when it comes to real performance,you have to pay to play. That's why everyone does the 1:6 rockers, not too huge a expense and it's a pretty quick 15-20 h.p. change. I just think I'd spend my money where it will make the best improvement to the car. Better gears will transform the car give you a much better seat of the pants improvement and give a better platform for later improvements. I myself would still like to do the 1:6 rockers but I'm looking for used parts where I don't have as much into it.
