My engine is torn apart !!!!!!!
Old Sep 19, 2009 | 06:44 PM
Calderone's Avatar
Calderone
Default My engine is torn apart !!!!!!!
This was the 87 last ride,and last video 2 days ago :
Yes !!!!!
The party just begun !!!!!
Today,the head/intake removal process is done,to make way
into a cool set of AFR195 heads ,Breath better with a Lingenfelter Super ram and energized by a Lingenfelter 219 Camshaft and a set of Crane Cams Gold series 1.6 Roller Rockers plus 1 5/8 Hedman Long tube headers.-
I gave away all the heads bolts,i will buy a new set of ARP ones
is there a specific model / type of bolts i should use ?
All advices are welcome !
Here i want to share with you guys what's going on
First thing i took away runners and fuel rail,on its place a cool set of 24 pounders from http://www.fuelinjectorconnection.com will rule !
Bye Bye TPI
Top view with dizzy still in place :
Accidentally i destroyed the 9th,Cold start injector pigtail...but i won't use that with the Super Ram..
Base is gone :
Base :
General view
Last view of the 128's ...bye darling :
Bye Sweetheart,thanks for all :
Top view :
Cylinder view,this engine was rebuilt on March,08 :
1-3-5-7 Driver side cylinders
2-4-6-8 Pass side cylinders
Gaskets :
Current shape :
Its a long way if you wanna rocknroll,the quest has begun.-
Thank you guys for all the help and knowledge sharing, i will need
a lot of advice on this one , this is just the beggining !
Sammy
Old Sep 19, 2009 | 07:26 PM
JackDidley's Avatar
JackDidley
Looks like you have been busy. If you have a shopvac they are great for sucking the debris out of the cylinders and lifter valley.
Old Sep 19, 2009 | 07:28 PM
jvette44's Avatar
jvette44
Sammy, Good Luck on this adventure!!! Wow!! You sure jump in all the way!! Hope everything goes smoothly! p.s. Nice video!
Old Sep 19, 2009 | 08:13 PM
beans-n-icewater's Avatar
beans-n-icewater
Originally Posted by Calderone
The detail on this cylinder is tough to make out...any better shots available?
Old Sep 19, 2009 | 08:16 PM
Calderone's Avatar
Calderone
Thanks !!!!!
Jack,yes i did clean after the pictures but there was little silicone that fell off when i dismounted the the base,engine was pretty clean !
Thanks J ! Yes im expecting to get huge gains,my current setup was :
128 heads+stock tpi+zz4 cam+stock rockers
im going :
afr195s+Superram+LPE219cam+1.6rollerrock ers+Longtube headers+CustomChip
and i will add the 24 pounders and the Adjustable fuel pressure regulator.-
Beans,nope,i dont have a better shot but i can take a new one tomorrow.-
but all the cylinders looks pretty much the same,the hone its still there and
i removed some of the carbon of the pistons trying to wipe off the coolant
i accidentally let in when i removed the heads.-
Old Sep 19, 2009 | 08:26 PM
beans-n-icewater
Thanks !!!!!
Dont go to any trouble or anything.... I tore down an L98 several years ago that had a similar looking "rusty" type scale on the number two piston
I was just curious if they were all like that or if it was just a random occurrence...
Happy wrenching!
Old Sep 19, 2009 | 09:08 PM
tpi 421 vette's Avatar
tpi 421 vette
You can still see hone marks in the cylinders. That's a good sign!
Old Sep 19, 2009 | 10:44 PM
Pwnage1337's Avatar
Pwnage1337
Damn, how long did it take you to do all this?
Old Sep 19, 2009 | 11:25 PM
383vett's Avatar
383vett
Good luck with the project. Next time pull the knock sensor on the passenger side and the plug or fitting on the driver's side so coolant doesn't go everywhere including the cylinders. As suggested, shop vac that stuff out of there, dry the walls and WD40 them so they don't rust while you're waiting for the heads.
Old Sep 19, 2009 | 11:26 PM
Weav's Vet's Avatar
Weav's Vet
WOW Sammy..........you jumped in with both feet didn't you! I don't see how you are doing this in such a tight space. Good luck and keep the pics coming.
Old Sep 20, 2009 | 04:19 AM
Calderone's Avatar
Calderone
Happy wrenching!
Thanks ! i guess its pretty normal
Yes i think so ! my engine has been running for a year and a half and its not a daily driver at all
Thanks !
i didn't do it and coolant was everywhere ,first timer !
Yes i will wd40 em !
i pulled the heads here only,when i get the rest i will pull the engine off the car and i will move it on a flat bed.
I started at 9am and stopped at 3 pm...
To My engine is torn apart !!!!!!!
