Valve Seals
Old Sep 21, 2009 | 07:55 AM
shamdave's Avatar
shamdave
Default Valve Seals
We changed my valve seals yesterday WITH OUT removing the head! I was not that tough but time consuming. If any one wants the how to let me know (beretta nut did all the hard work) that guy knows his poo! I am sure he will be glad to post the how to if any one is interested
Old Sep 21, 2009 | 08:28 AM
rodj's Avatar
rodj
Not to dump on your party but who told you the heads had to come off to change valve seals?
Old Sep 21, 2009 | 09:44 AM
shamdave's Avatar
shamdave
I thought it was common knowledge I am sure I am not even close to the first so i was just tring to pass on info to other novices like my self
Old Sep 21, 2009 | 11:23 AM
bomar76's Avatar
bomar76
Did you sand them with 60 grit paper first?
Old Sep 21, 2009 | 11:38 AM
shamdave's Avatar
shamdave
40 grit
Old Sep 21, 2009 | 06:49 PM
powerpigz-51's Avatar
powerpigz-51
Hey Dave.....hows the project goin'? I just did my seals on my "rebuilt" heads.....they had left off the o-ring seals underneath the keepers. Now I know why....what a pain in the..... My car was smokin' really good, now not even a puff. Took me about 2 days. Hows the paint?
Old Sep 21, 2009 | 08:08 PM
shamdave's Avatar
shamdave
Its coming We have it blocked down and now we are fixing to prime it thursday and then sand some more hopefully a couple more weeks
no more smoke but we need to readjust a lifter (have a tick) of course on the drivers side
Old Sep 21, 2009 | 10:30 PM
kenv's Avatar
kenv
From: levittown pa. usa Even a bad day with my `Vette, is better than a good day at work
St. Jude Donor '10
I changed the valve seals in my `87 without removing the heads by using the old "rope" trick, Worked like a charm
Old Sep 22, 2009 | 10:28 PM
pletzvet's Avatar
pletzvet
sand them first??? Sand what first? Never heard of this...
Old Sep 23, 2009 | 01:19 AM
Qiken's Avatar
Qiken
Im with you
Old Sep 23, 2009 | 12:06 PM
powerpigz-51
Someone was just gettting his digs on Shamdave for sanding the paint off his car with 40 grit sandpaper....it was a epic thread some time ago. The car is being repainted properly as we speak. I am rooting for him.
Old Sep 26, 2009 | 10:27 AM
Loosenut_Beretta's Avatar
Loosenut_Beretta
It was only one that needed another 90* turn, but how's she doing now? It's not killing bug's anymore I hope. How did the priming turn out?
Oh is the power draw gone?
Old Sep 26, 2009 | 10:30 AM
Loosenut_Beretta
Rope trick?, you must explain, I must have that knowledge also.
Old Sep 26, 2009 | 05:56 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Stuff some nylon rope through spark plug hole, rotate crank to put piston at TDC, remove springs.
Old Sep 26, 2009 | 06:33 PM
Loosenut_Beretta
Fancy, even I didn't think of that, thank you for answering it like a nice guy.
To Valve Seals
