headlight question?
Old Sep 28, 2009 | 05:12 PM
desertmike1's Avatar
desertmike1
Default headlight question?
(1995) R/H Headlight would not open fully, and would not close at all. I installed a new Gear & Bushings (old set looked ok coming out) tested the headlights with the hood up, and the R/H headlight checked out just fine.
After putting away my tools and closing the Hood I tried my headlights one more time, and the R/H hung up again
I looked at the linkage when I had it apart, I didn't see any issues, all the joints were clean and moved freely, is it possible that a slight amount of bushing wear could lead to a problem like this?
Anyone else experiance this problem...
Old Sep 29, 2009 | 11:57 AM
josephf31's Avatar
josephf31
Default Sounds like
the motor is shot
Old Sep 29, 2009 | 02:29 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Did you test your headlight control module? It's located on the driver's side on the lower fender well.
Old Sep 29, 2009 | 02:49 PM
desertmike1
(Update)
Last night I tested the headlight with the hood open and it worked fine. I closed the hood, and the light hung at 3/4 open.
So I inspected the area just above the coolent recovery tank were the headlight "rotates", and there it was, a rub mark in the aluminum pipe that connects to the coolant recovery tank.
I gently pushed the pipe inboard about 1/4" and now the headlight works with the hood closed.
Old Sep 30, 2009 | 11:51 AM
josephf31's Avatar
josephf31
Default Cool
(Update)
sometimes it's the simple things, I like when that happens!
To headlight question?
