Is it possible to have plugs that fire partially? My #1 and #2 cylinders do not seem to firing correctly. I used a heat gun to check the temp at the header on each cylinder. It was noticeably lower on these two cylinders.
Actually a tough question cause there are so many possibilities. Rather than a straight answer let me ask you some questions. Compared to the other 6 cylinders how do the cooler cylinders compare to the following:
Glad to hear you got it sorted out. What happened?
Nothing major I just had the wrong length rods and the valves weren't working correctly. See my "Parts for a cam swap" thread".
Originally Posted by Muffin
What led you to a push rod?
Mainly I wasn't satisfied that the RR's I had that were so quiet before were now rattling like a diesel. The rods were binding against the guide plates. No harm done got it all square away and the car runs great. At least on the stands. I hope to get it down today.
