Twin Turbos
Old Oct 3, 2009 | 04:09 PM
  #41
eilax053's Avatar
eilax053
Originally Posted by pr0zac
next week i am going to start on building a rocketship to fly to the moon.. i have no engineering background or idea of flight and its principals or propulsion. but i got $20 and i think i can make it happen.. wish me luck..
Aww man I got $20 too. can i go in on this project with you 50-50
Old Oct 3, 2009 | 04:12 PM
  #42
eilax053's Avatar
eilax053
As of now I am researching another way to get my hands on a set of turbos. I'm starting to not like the ebay ones
For those who can answer this...
What size A/R would you guys go with. I have done calculations and came to a conclusion that the .42A/R is just too small.
I was planning on going with a .60A/R... I know there are alot of other things that depend on this but i still ask the question
Old Oct 3, 2009 | 05:16 PM
  #43
Calderone's Avatar
Calderone
You said you want 5 psi only....you have your own answer
Old Oct 3, 2009 | 05:29 PM
  #44
Calderone's Avatar
Calderone
69427 and c4cruiser both have good points.
Cory, you said its not your daily driver and that will be your daily driver once it gets insured
Now you don't like the ebay turbos,and you name ".42A/R" and ".60A/R"
Well i will give you MY ADVICE ...
With 125k your engine is tired,thats what i think.-
If you know that you can mess it up,go for it !
But if you want power,build a N/A engine,build a healthy 350,355 or maybe a 383
if you have the funds you can always get a 421,im sure that will be pretty quick
Much more than a 205 hp turbo engine that makes 300 hp ...that makes no sense
My choice would be N/A...all the way,then...if you have forged pistons and rods
Supercharge it,you can do 600-800hp depending on what are you supercharging...
but that takes a lot of $ $ $ $
and btw ...a few posts above i read that you asked if going with .42A/R or .60A/R
No offense but that statement made me watch your profile and makes me think you called a friend or something.....
Cory,you are still in high school,i really hope you have the funds to do all of this
we'll see down the road !
Best of wishes ! and im sure if you build a healthy N/A it will be cheaper
and way powerful ! i always see SC and Turbo as add-ons
Imagine your impeller breaks....you'll be making 205 hp again !!!!
Old Oct 3, 2009 | 05:54 PM
  #45
eilax053's Avatar
eilax053
Old Oct 3, 2009 | 07:50 PM
  #46
ekess744's Avatar
ekess744
5psi would be a horrible return on investment... lots better options to make that much power for the money
Old Oct 3, 2009 | 08:03 PM
  #47
pr0zac's Avatar
pr0zac
Originally Posted by Bad Karma
I didn't see in your profile if yoru car was stick or auto, but it you have a manual the Dana 44 will handle a good amount of power and doesn't need to be so high on the list. Your stage 1 needs to be turbo and fuel system you can't add boost without adding fuel you are asking for disaster.
i am pretty certain 84's only had d36's..
Old Oct 3, 2009 | 08:10 PM
  #48
pr0zac's Avatar
pr0zac
fyi -if you break an impeller you are going to be making any horsepower.. ebay turbos are crap. end of story. you are going to want at least some t3/t4's to be able to do what you want and still be able to turn up the wick when you get a decent engine. its going to be way harder than i think you are anticipating..
Old Oct 3, 2009 | 10:44 PM
  #49
Calderone's Avatar
Calderone
when i first got here i started asking for 500 hp and wanted more power...
http://forums.corvetteforum.com/c4-g...you-think.html
Old Oct 13, 2009 | 01:14 PM
  #50
Bad Karma's Avatar
Bad Karma
Originally Posted by eilax053
Thanks for all the info/tips
You said that you have done turbo installs before but how did you get your experience? You had to do your first one eventually right? This is my first one and I know I'm gonna make errors and not alot of things will go as planned. thats why I am asking these questions
I kind of lost track of this one for a bit.
I had a good basis in turning a wrench and doing bolt on installs, engine R&I, basic tuning (piggy back), etc. Met a guy through the car clubs that had his own small shop, excellent welder! great fabricator. He asked me to come work with him and I gained experience and learned some fab skills, and a lot more about turbos than I knew before.
The key is research and practice. Garret has some good info online including how to run through the calculations to see if a turbo is properly sized for you and not going to surge or be too small for your app. There are some good books out on turbo charging as well. The old standby for a lot is Maximum Boost by Corky Bells, I can't think of some of the other ones off the top of my head.
I disagree with a previous posted that 5 psi isn't worth it. It's a good starting point, to start tuning from. You can't crank up the boost to insane levels until you build up other parts, and a low boost level gets you more power and your feet wet into tuning.
One more bit of advice. Look at what budget you think you have an increase it by probably 50% The little parts add up surprisingly quickly, and if this is a daily driver I would plan enough extra money to at least drop in a cheap replacement engine should something happen during tuning.
Old Oct 13, 2009 | 01:56 PM
  #51
ndanl's Avatar
ndanl
Old Oct 13, 2009 | 02:42 PM
  #52
rick lambert's Avatar
rick lambert
Why all the negativity? There's been lots of guys who have done turbos, and I agree 5 psi is a great place to start. I'd even go with the turbos you started with, not the best, but at the cost you'll gain alot of experience and won't lose to much $$$ if it does go TU.
Old Oct 13, 2009 | 04:07 PM
  #53
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
Checkout JoBy's '84 Corvette
He's run both a supercharger and a turbo
http://www.joby.se/corvette/
Old Oct 13, 2009 | 05:57 PM
  #54
eilax053's Avatar
eilax053
Well guys just a little update I took some of your advice and decided to put off the turbos for a little while until I have a stronger engine, tranny, and rear end. So as of now I am doing a 5.3L "LS1" Engine swap and already have most of the parts to do the build
Thanks for all the advice guys
Old Oct 13, 2009 | 06:04 PM
  #55
desertmike1's Avatar
desertmike1
Default Cool
Old Oct 13, 2009 | 06:08 PM
  #56
eilax053's Avatar
eilax053
Heres a Link to my engine build thread
http://forums.corvetteforum.com/c4-t...post1571808630
Old Oct 14, 2009 | 11:49 AM
  #57
Bad Karma's Avatar
Bad Karma
I hope it gets turbo(s) after it's in there!
To Twin Turbos
Old Oct 14, 2009 | 05:37 PM
  #58
TLS_Addict's Avatar
TLS_Addict
Originally Posted by pologreen1
84 is forgeed and with gears headers, ETC you can probabaly pick up a couple of seconds atleast.
There is an article somewhere of an 84 that was sooped up cheap and nitrous and now a fast car.
just google it.
unless you have plenty of money tools and fab potential then change everything out and twin turbo it.
84 engines have forged internals?
Got the link? I am lazy....lol
Old Oct 14, 2009 | 06:40 PM
  #59
pr0zac's Avatar
pr0zac
they have forged pistons...
Old Oct 14, 2009 | 06:52 PM
  #60
eilax053's Avatar
eilax053
I plan on it
