Twin Turbos
Old Oct 15, 2009 | 09:43 AM
  #61
TLS_Addict's Avatar
TLS_Addict
Originally Posted by pr0zac
they have forged pistons...
ow about the crank? What type of rods? Didnt they switch to a cast piston later in the C4 line?
Old Oct 15, 2009 | 01:13 PM
  #62
pr0zac's Avatar
pr0zac
i don't konw if the l98's were cast but the lt1's were hypers.
Old Oct 16, 2009 | 09:39 AM
  #63
CooterCatchinVette's Avatar
CooterCatchinVette
On cardomain.com theres a user "agentallamerican" who had Engines by Unser in CA put together a custom turbo for him. Might want to give them a call. Good luck with the LS1 swap.
Old Oct 16, 2009 | 12:26 PM
  #64
Bondami's Avatar
Bondami
From: Southside of Western Norte Americano State of Confusion, ColoFornia
St. Jude '13
Im no Turbo expert.. but ummm 2 questions.. if you are looking at 4-5 pounds of boost.. why use 2 turbos? and is there actually room for all that? I would think that a small single twin scroll turbo would be sufficient to generate 5 pounds of boost, and depending on where you live.. 2-3 pounds of boost will get you to sea level equivalent which the stock system should certainly handle.. Good luck with it.. if nothing else, polish hell out of it, it will at least look cool..
(Im thinking I would scrounge salvage yards for a turbo (the new Mini Coopers have a very nice responsive unit) before I would buy the Chinese version.. if something comes apart those pieces are going down the engine..)
Old Oct 16, 2009 | 01:18 PM
  #65
Bad Karma's Avatar
Bad Karma
Twins should spool faster, but you are right at 5 psi, it's not a big deal. But if this is just an early stage and plans for more boost and you want twins, then do your fabrication as twins to start, so you are not reinventing the wheel to switch between twins and single.
I looked at mine and the lay out, single looks like an easier option to me for keeping AC. But it's up to the person doing the fab. work.
Old Oct 17, 2009 | 02:29 PM
  #66
Orr89rocz's Avatar
Orr89rocz
For his goals you will need a small set of twins. Its easier to find a single turbo that will meet his goals. SIngles will spool near instantly when sized right. He doesnt need to go big because he's only looking for 5psi boost and keeping power very limited.
i'd shop around for some used turbos for sure for this buildup. Key is finding a good wastegate and having a spring in there that can control down to 4-5lbs. If not, you will see more than 5lbs and seriously risk blowing that motor.
As far as cheap ecm control, convert to 91-92 730 ecm speed density setup with 2 or 3 bar map and run either code $58 or the newer improved code $59 files from GM turbo trucks syclone/typhoon.
I'm running a 730 ecm with code $59 on my twin turbo 401with 10psi with no real problems so far. Had difficulties along the way but its close to being all figured out now. My wastegates are not in great location however and my 6-7psi spring acts like 10psi spring. The design of the system needs to be optimal to accurately control boost to those low levels.
