Another Crate Engine Thread
Old Oct 3, 2009 | 07:45 PM
Pwnage1337's Avatar
Pwnage1337
Default Another Crate Engine Thread
http://yearone.org/serverfiles/fbsho...26DJ73491&trk=
Can anybody find a crate engine with the LT4 camshaft and Vortec heads on it?
There are people making some pretty good power with Vortec heads over on TGO, I am wondering if it would be possible to find the same engine for less from a different dealer.
Old Oct 3, 2009 | 08:11 PM
pr0zac's Avatar
pr0zac
lt4 hot cam? if i were you i would go on ebay find a used vortec motor rebuild it with a decent cam and drop it in.. done way cheaper.. hell i found a running lt1 with a transmission accesories harness computer and pcm for $1300.. dropped it in and drove it like i stole it..
Old Oct 3, 2009 | 08:46 PM
Pwnage1337's Avatar
Pwnage1337
The crate engine comes with a hyd roller cam with the same exact specs as the LT4 Hot cam.
http://cgi.ebay.com/ebaymotors/L31-C...=p4506.c0.m245
And slap some vortec heads on it?
Old Oct 3, 2009 | 09:15 PM
rodj's Avatar
rodj
Cheaper still
http://paceperformance.com/index.asp...&ProdID=184534
Which Vortec heads are you looking at?
For $1000 v $600 for Vortec's you can get a TFS head that doesn't need a special intake .The stock Vortecs require machining / or spring change to run higher lift cams
http://www.speedwaybids.com/tech/Vor..._Max_Lift.html
http://www.2quicknovas.com/vortecheads.html
Old Oct 3, 2009 | 10:02 PM
ekess744's Avatar
ekess744
crate engines are good for people that don't have time or don't want to learn. My 383 has quite a few nice parts because I chose to build it myself and save a bit. set aside atleast 2000, 4000 if you want nicer parts.
Old Oct 3, 2009 | 10:08 PM
Pwnage1337's Avatar
Pwnage1337
Well the way i see it, i can probably buy all the components of the crate engine for about 2400 dollars. For the other 600, i can get a 3 year warranty.
Old Oct 3, 2009 | 10:18 PM
ekess744's Avatar
ekess744
or you could learn something and take a little more pride in what you are doing
Old Oct 3, 2009 | 10:27 PM
Pwnage1337's Avatar
Pwnage1337
I was thinking about building it, but I'm only 17 (soon to be 18) and I don't have much experience with the bottom ends of engines. The last thing I would want to do is spend $2,000 dollars and put it together and blow it up. I am going to tinker with the old block if i decide to go the crate engine route.
Another factor affecting my decision is that I don't have the space to do it. The garage is consumed by vehicles in winter because of our awesome climate here in Wisconsin.
I have a lot of pride for it, its not like I am stealing the parts, i still work very hard for all of my money which goes towards the car.
Old Oct 3, 2009 | 11:42 PM
rodj's Avatar
rodj
I think the shortblock mentioned is a good starting point for a newbie. He still has to learn cam / timing / heads / rocker install without worrying about ring gaps and bearing clearances which many here on this forum would not undertake anyway.
Old Oct 4, 2009 | 12:06 AM
Pwnage1337's Avatar
Pwnage1337
Would building short block be cheaper than buying the crate motor? I really do want to learn, i am going to school after high school for automotive mechanics/body.
Old Oct 4, 2009 | 12:49 AM
rodj's Avatar
rodj
The "crate " motor you list above is a short block.
Someone has to supply and install cam , timing chain, oil pump , pan , heads , etc on it so it may as well be you .It is all bolt on stuff
Old Oct 4, 2009 | 01:43 PM
ekess744's Avatar
ekess744
I can agree with that for sure
Old Oct 4, 2009 | 02:26 PM
Pwnage1337's Avatar
Pwnage1337
The engine from Yearone is a crate engine. Its already assembled with the cam, timing chain, oil pump, pan, heads. It needs my TPI intake (which I have to buy a vortec base for), vette accessories etc.
The shortblock route might be a good route, provided it is cheaper than the crate engine. I would love to learn, plus it gives me something to do during the winter. Maybe I can pursuade dad to park the car outside for a month.
Either way, I want to build that exact engine. With the LT4 Hotcam, Vortec Heads.
Old Oct 4, 2009 | 04:30 PM
nutz4c4's Avatar
nutz4c4
The Year One motor isn't a bad deal but remember that the Vortec TPI base plate is $400 to $500. Maybe you could work out a credit for the manifold on that crate motor.
You won't make that H.P. and torque with the TPI tho. Good luck with your project.
Old Oct 4, 2009 | 08:36 PM
rodj's Avatar
rodj
The engine from Yearone is a crate engine. .
I was refering to the 2nd link you posted obviously
Need to crunch the numbers.
Do you have a engine to get parts off? fasteners ,oil pan, timing cover ,pushrods, possibly roller lifters if in good cond etc.
If you have to buy new then the cost difference could blow out.
Otherwise you need cam , timing set , heads , oil pump.
Could get a different cam so you don't need 1.6 rockers that the Hot cam needs
Old Oct 4, 2009 | 10:24 PM
ekess744's Avatar
ekess744
I don't understand why you are looking at 350s when you're just gonna put a tpi back on it. Thats what you have. You could just put better heads and 1.6 rockers most likely end up with nearly the same results as the crates you are looking at.
Do you have good evidence that you need a rebuild?
I only am suggesting that you think it over because that intake won't demand much out of the shortblock or valvetrain.
If you are going to rebuild, I think you should set your sights a little higher for a hp goal
Old Oct 4, 2009 | 11:20 PM
gotmy85's Avatar
gotmy85
Next newbie question here - what can you do to max out the capabilities of the TPI system? I might be looking to do something like this down the road on my 85, but will be in trouble knowledge-wise if I have to R&D my way into something that works. I do want 400 HP, which doesn't seem like much these days.
To Another Crate Engine Thread
Old Oct 4, 2009 | 11:23 PM
pr0zac's Avatar
pr0zac
yes but who's to say the condition of the bearings in the motor will withstand the extra stress in the increase of horsepower and rpm?
Old Oct 4, 2009 | 11:38 PM
ekess744's Avatar
ekess744
I was mostly wondering what condition the short block is really in.
Old Oct 5, 2009 | 08:12 AM
hip's Avatar
hip
Default crate engine
If you are going to buy a crate engine, read the fine print about-installation, modifying, oil changes, ect. it will surprise you
