Header Install/Prep Work (L98)
Old Oct 9, 2009 | 01:22 AM
Calderone's Avatar
Calderone
hmmm not sure about the pipe gauge differences
Old Oct 9, 2009 | 06:43 AM
cshuman's Avatar
cshuman
Looks like a great combination. I'd be interested to know how much resonance, if it has any, that this system would have. Keep us posted.
Old Oct 10, 2009 | 01:05 AM
Gryz88's Avatar
Gryz88
I promised you guys progress pictures.
A tip to anyone who is going to do this project, take the spark plugs off before you attempt to take the exhaust manifolds off.
drivers side, headers off, air pump off, alternator laying to the side, belt off, plugs/wires off
passenger side bent dipstick, air stuff removed
passenger side, A/C portion off, headers off, smog off, belt off, plugs/wires off
dipstick bent halfway down, while removing stock exhaust manifold
stock exhaust manifolds and plugs
of course, dad had to highlight my Polish Hood Lift (stock one doesn't always stay up, yes we've both been hit in the head before), while also showing his badass Z06
Old Oct 10, 2009 | 01:34 AM
Calderone's Avatar
Calderone
Looks tight ! My header installation will be easier,i have opened more way for them :
Old Oct 10, 2009 | 09:31 AM
z06roadkiller's Avatar
z06roadkiller
St. Jude Donor '12
Originally Posted by AGENT 86
As you probably know, I am using those Headmans. Stock starter is still in place and I'm using the supplied gaskets and Breslin locking bolts. You will need to make a new dipstick mount. I just cut the stock bracket off and formed one to hang onto the tube and bolt to head.
Based on Agent 86....we decided to leave the stock starter in place & plan on removing the headers out the top. That meant the AC compressor coming out on passenger side. A couple of things (tricks) learned the hard way on the headers removal....(1) after AC removal, keep AC/tension bracket as loose as possible....you need every mm to lift header out top and (2) you may as well take the dipstick out early going out the top...end up bending it anyway.
Here's a pic of big-little brothers during header removal I think the LS7 is jealous the L98 is getting soooo much attention
Old Oct 10, 2009 | 11:10 AM
Gryz88's Avatar
Gryz88
No **** you've got it a little more open..I think you've got more off then on that engine bay. Are you switching out the heads?
Old Oct 10, 2009 | 11:17 AM
Calderone's Avatar
Calderone
Yes i will be installing installing this combo : AFR 195 heads,Lingenfelter 219 cam,1.6 roller rockers,Accel SuperRam (lower and upper),1 5/8 Hedman Longtubes,im expecting a little difference to my near-stock set up i had.-
what u think
Old Oct 10, 2009 | 11:29 AM
Gryz88's Avatar
Gryz88
I think thats a hell of a project, and your going to see about 10x greater gains then I will off the exhaust, do you have a thread going where I can follow your progress? PM it to me.
Old Oct 10, 2009 | 11:31 AM
Calderone's Avatar
Calderone
Not really yet,i will post one very soon
i will keep you posted !
Old Oct 10, 2009 | 10:13 PM
Gryz88's Avatar
Gryz88
Just made this nifty discovery, Hedman makes a Reducer with the O2 Bung already welded on there. This reducer will also take it from 3" from the collector to 2.5" which is what I need for the Pypes System.
Do you guys think $22 is a fair price for this? I have no idea what an exhaust shop would charge to weld one in?
Old Oct 10, 2009 | 10:18 PM
Calderone's Avatar
Calderone
Do the included reducers go from 3" to 2.5" as well ?
Old Oct 10, 2009 | 10:36 PM
cumbercr's Avatar
cumbercr
I'm jealous of this father-son project. I have three daughters that couldn't care less about cars. My dad is 81. He's scared to death to sit in my C4.
Calderone - You get those AFRs and Super Ram yet? You're goona love the combination. I almost lost it the other day shifting between 1st and 2nd. I'm still getting used to the power gains.
Old Oct 10, 2009 | 10:42 PM
  #33
Calderone's Avatar
Calderone
cumber,super ram and 74219 cam are done,im putting together the money to pay the heads now,tell me more about your combo and what you feel drivin it !!!
does it feel that its "more than you can control" if it feels like that ...its right !!!!
The only thing that secretly torment my crazy mind is that it will be a 355 and not a 383
which its the perfect combo...i cant afford a stroker kit after this head/cam/intake upgrade
Old Oct 10, 2009 | 11:33 PM
  #34
pivotpro's Avatar
pivotpro
Just found your thread. I am installing the identical setup with the hedman and Pypes this tuesday. I am using a lift next door, that should make it easier. This one is a father daughter project and we are about to wrap it up next week.... complete teardown of the car and recolor inside and out. The new Pypes exhaust fit perfectly in the outlets of the lower valance. My only worry is that it will be a bit too obnoxious (loud) for a DD.
My headers have the bung welded into the collector already. I read on Hedmans site that the AC bracket would need modifying. Please let me know how that affects things on your project. I will keep watching.
Old Oct 11, 2009 | 12:19 PM
  #35
Gryz88's Avatar
Gryz88
I sent a question to Summit Racing about that yesterday, When I hear back from then I'll let you know.
Where did you buy them?
I am installing the identical setup with the hedman and Pypes this tuesday, Please let me know how that affects things on your project.
Were not putting them in till mid November, when I get back from school for Thanksgiving. Why don't you let me know how it went
Old Oct 11, 2009 | 01:25 PM
  #36
HlhnEast's Avatar
HlhnEast
Before you buy, read member's posts on each company's headers and then make your decision. Alot of headers have fitment issues and require alot of modding of your car and maybe the headers themselves. Sometimes the ease of installing is worth the extra money. Its kinda like buying the extra thick tubes (14 ga) or ceramic coating for durability. Other more pricey headers usually have the fitment issues worked out. As far as Hedman's, I cannot say for the Vette but I have pretty much stuck with them on everything else I have owned with good results.
Anything you can do to prevent rework is worth it in my book. The best gaskets, locking bolts, etc are probly worth it in the long run if you dont want to continually be back under the hood. Its hard enough to do it the first time and worse after the assembly is complete. Choose carefully after research and good luck!
Old Oct 11, 2009 | 05:36 PM
  #37
pr0zac's Avatar
pr0zac
i have an lt4 but i was able to install my headers with the car on jackstands with only the front tires off the ground.
To Header Install/Prep Work (L98)
Old Oct 12, 2009 | 04:10 PM
  #38
Gryz88's Avatar
Gryz88
No, just hered from summit. They go from 3" to 2.25", which would make sense if I was going back to the stock exhaust but looks like im going to have to order 2 reducers, one with the O2 bung welded one without.
Old Oct 14, 2009 | 10:04 AM
  #39
Yorcci's Avatar
Yorcci
Originally Posted by Gryz88
I've been looking to this thread religiously for info ever since deciding on the hedders. Page 2 specifically has a great walkthrough, translated from a swedish website. From this it appears I can actually keep the stock starter. (we'll see about that when I get there)
Swedish?! SWEDISH?! It's Finnish, from the next country, Finland. There's a difference. It's called "border" (No real offence taken, don't worry.) Both the original text (in Finnish!) and the translation is written by me...
I also had a couple more questions for the forum veterans.
2) I've seen alot of guys go with the Fel Pro Gaskets, are they worth the extra $20, over the gaskets that come with the headers?
3) I've read that some people use Locking Fasteners, once again are they worth the extra $46 over the bolts from Hedman?
2) I haven't had any problems with the gaskets that came with the headers. I've driven ca. 6 000 miles after installation and no sign of loosening bolts. I also did take a day at a raceway with the car.
But the three bolts connecting those flanges after collectors came loose. I had to tighten them several times and on that day at the track I lost two bolts and four nuts. Just thought that the flanges got a little loose, because the exhaust sound got a little louder than normal on the way home. Well, they were more than a little loose...
Old Oct 14, 2009 | 10:07 AM
  #40
Yorcci's Avatar
Yorcci
Yes. I mean those ones, which came with headers.
