Engine hoist question
Old Oct 6, 2009 | 08:51 AM
mavrick331's Avatar
mavrick331
Default Engine hoist question
Where can I attach chains to lift my LT1 and 4L60e together ? It was delivered on a pallet yesterday and is going in an 87 Jeep YJ that I have torn down to the frame. I need to test set it in to align my motor mounts.
I have a hoist and load leveler and don't want to buy the hooker device, mainly for time's sake.
Thanks,
Rick
Old Oct 6, 2009 | 10:43 AM
Dale1990's Avatar
Dale1990
St. Jude Donor '15
When I was moving around my spare L98/ZF6 I used chains bolted to the front and rear of the heads. One bolt in front on one side and one bolt in the rear on the other. It would have been nice to have a leveler but it lifted the assembly w/o incident.
Old Oct 6, 2009 | 11:54 AM
lt1396corvette's Avatar
lt1396corvette
with dale1990. But If you did have the happy hooker lift plate I don't think you can lift the engine and tranny together.
Old Oct 6, 2009 | 02:07 PM
reoch999's Avatar
reoch999
I did not have a leveller, but it went as smooth as it could have gone.
I attached the chain using the intake manifold bolt holes, the front one on the left side and the back one on the right side. Of course, I have the 700r4, but I don't think there is more than a couple pounds weight difference.
Old Oct 6, 2009 | 03:07 PM
JAKE's Avatar
JAKE
I use the cylinder heads bolt holes, too. Passenger side FRONT and driver's side REAR.
I make sure that the grade 8 bolts I choose can screw in until almost bottomed out in the head but don't extend more than an inch from the heads. This prevents the weight from applying any excessive bending loads to the bolts.
Remove anything that contacts the chain, like maybe the throttle body or valve cover(s) to prevent the chain from breaking them once load is applied to the chain. A folded towel(s) prevent the chain from scratching other parts.
Hope this helps.
Jake
West Point ROCKS! Nation's TOP COLLEGE per Forbes Magazine!
Old Oct 6, 2009 | 08:45 PM
mavrick331's Avatar
mavrick331
Thanks all,
Hooked to front pass, rear driver side heads and it worked with no problem. Now that it's in the air, I can see its one filthy, oily SOB !!!
I got my work cut out for me !!
Thanks,
Rick
To Engine hoist question
