Internal motor problem? need help bad!
Old Oct 8, 2009 | 05:41 PM
cwyates4's Avatar
cwyates4
Default Internal motor problem? need help bad!
Well, today I was driving the vette and it started to not want to rev past 2K. It would shake real bad and the motor seemed to hit a wall. With no load, the motor revs to 6500 just fine.
With the car idling, the motor has a noticeable tap like lifters and it makes a nice pop through the intake when you snap the throttle.
Broken valve spring? or bad rocker arm?
Old Oct 8, 2009 | 06:46 PM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
Lots of things can cause a drop in power. How does the car idle? You can remove the valve covers to check the valvetrain.
Old Oct 8, 2009 | 09:39 PM
Muffin's Avatar
Muffin
Pull the valve covers.
Old Oct 9, 2009 | 04:31 AM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
And the sooner the better! Don't run it until your sure a valve isn't going to kiss a piston.
Old Oct 9, 2009 | 08:56 AM
rodj's Avatar
rodj
Mine was similar except I had a chuffing out the exhaust
Luckily the retainer was jammed on the valve and the broken spring wound inside itself so it was still operational at full travel but was not fulling valve back on the seat when closed.
Old Oct 9, 2009 | 08:56 PM
cwyates4's Avatar
cwyates4
Car wont be driven again anytime soon....just bought a brand new....mustang....
Anyway, the motor was idling very bad at cold temps, once warmed up it was pretty smooth. I pulled the valve covers today and it all looks pretty tight under there. Some of the rockers are too tight, and one is a little loose, but nothing that would cause what I have experienced. Starting to think possibly a lifter or even the cam. Next step will be to do a compression check and turn the motor over by hand and watch the valve train. I'll keep y'all posted, but I'm a busy bee!
Old Oct 9, 2009 | 10:38 PM
engle1147's Avatar
engle1147
Done any air/fuel mods lately? A really "rich" condition will do what your describing.
Old Oct 13, 2009 | 11:16 AM
cwyates4's Avatar
cwyates4
No I havent done any lately. Its always ran rich, and doesnt smell any worse.
I'm pretty stumped, its just wierd that with no load the motor runs great other than the slight tappets noise, but under load over 2K the motor starts to shake badly and makes a high pitched metallic noise or the noise similar to a badly squeeling belt.
Old Oct 13, 2009 | 11:21 AM
JackDidley's Avatar
JackDidley
I'm going to take a guess and say the squeal Is a bearing spinning. Something inside is broke. You can have the oil pan off in 1/2 hour. Just saying....
Old Oct 13, 2009 | 11:30 AM
cwyates4's Avatar
cwyates4
Well, that is my guess too....so wierd that it just happened out of no where cruising on the highway.
Old Oct 13, 2009 | 11:31 AM
Midnight 85
spun bearing. Cord, you sure have rotten luck. You may not need to pull the pan to find out, drain the oil through a paint strainer and see what you find.
Old Oct 13, 2009 | 12:22 PM
desertmike1's Avatar
desertmike1
Let's not forget about the ignition....did you hear tappit noise prior to this problem?
If you check your distributor TDC, and it's off, this could indicate a timing chain problem. Late valve/ignition timing will give you a week engine performance.
Old Oct 13, 2009 | 08:11 PM
CorvetteMike2024's Avatar
CorvetteMike2024
Corvette Enthusiast
Default new ride
How bout some pics of the new ride?
Corvette Mike
Old Oct 14, 2009 | 10:37 AM
cwyates4's Avatar
cwyates4
I haven't ruled that out, and no, the tappets started when the performance issue started.
I fired it up yesterday and heard a loud popping sound. the motor backfired and shot a vacuum cap off right at my valve cover. Smoke was coming out of the intake manifold, really whitish and whispy smoke.
Old Oct 14, 2009 | 02:58 PM
desertmike1
I had a leaking intake manifold on a 3.1ltr a few years back, anti-freeze was leaking both "internal" & "externally", this caused my lifters to tap loudly, a new intake gasket, and oil change cured my problem...do you have a leaking intake?
I would move forward with a prelimanary Distributor ignition timing check.
Old Oct 14, 2009 | 03:32 PM
SunCr's Avatar
SunCr
The 3.1's were a different animal with multiple Bulletins about leaking intake gaskets (which took a "compression set" in GM speak allowing the engine to suck a boatload of oil). This sounds like a blown head gasket. Pull plugs and rotate the engine by hand; then see if coolant flows out of any of the holes.
Old Oct 19, 2009 | 07:59 PM
cwyates4's Avatar
cwyates4
cracked valve seat on the exhaust side. Head will need milled which means both need to be milled. May be parting out, will update.
To Internal motor problem? need help bad!
