Accel super ram
Old Oct 14, 2009 | 08:26 AM
beergoalie's Avatar
beergoalie
2nd Gear
Default Accel super ram
Hello I'm a new member with a question. Just recently purchased an 84 vette, it cam with an Accel super ram. Having problems getting someone who is knowledgable enough to tune it up here in Canada. Wondering if I could go with a stock GTA wire/harness? It turns out the super ram computer is outdated so I kind of would like to go back to a stock wire/harness and computer. Is it best to replace the whole system or will a wire/harness and computer work off a 350 chev?? The engine has been modified but I don't have the specs. Any input would be greatly appreciated.
Old Oct 14, 2009 | 08:36 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Keep the SuperRam !!
Nothing special is required for that intake, it's what else has been done to the motor that may require a custom tune.
What computer is in there ??
Where are you located ??
Old Oct 14, 2009 | 08:41 AM
beergoalie's Avatar
beergoalie
2nd Gear
I'm in Brantford, Ontario Canada...It's a complete Accel system, computer, wire/harness etc. The performance shop said the software is too old, I would need an old laptop and patch cord. So I was just wondering if I could switch the computer and wire harness for one from a GTA but keep the rest of the system??
Old Oct 14, 2009 | 08:54 AM
AGENT 86's Avatar
AGENT 86
Well, I have no experience with Accel's computer, but it isn't as outdated as the stock computer that came with the 84.
There are members on here that have them, maybe another post looking for help with Accel's DFI systems, will find better help.
Old Oct 14, 2009 | 01:49 PM
383vett's Avatar
383vett
I'm using the Accel computer that came with the superram setup on my 84. The Accel Gen 6 is outdated but still works, it is just not as user friendly as a Gen 7. Mine is good for 10.50s. There is a book in the auto section at Borders or Barnes and Noble that covers the Accel Gen 6 system. If you can't find it there, it is available on ebay for about $13. Get it and read it. It's pretty self explainatory. Good luck
Old Oct 15, 2009 | 01:36 AM
ddahlgren's Avatar
ddahlgren
The Acell is a good piece I used to sell them many years ago and found them to be the most friendly for GM based engines around. The software is not very fancy but very effective. It has a buch of tables for drivability that are very useful and if the later softwrae with the idle spark feature very good for stable idle speed control. You need a laptop with a real serial port and will boot into a DOS environment I am thinking window 98 or 2000 but XP might work too and worth a try.
To Accel super ram
