Throttle Body Cleaning
Old Oct 14, 2009 | 09:17 PM
90WhiteLightning's Avatar
90WhiteLightning
Default Throttle Body Cleaning
Hi,
I have a 1990 with an L98. It has roughly 24K miles on it. I took the Throttle Body (TB) off so I could clean it real good and replace the Idle Air Control (IAC). To do a proper cleaning, do I also remove the 7-8 torx bolts that holds the bottom piece of the TB where the two coolant lines and IAC attach? If so, when I get a gasket kit, will the kit come with a gasket for where this bottom piece mounts to the TB? To properly clean everything, do I just spray it up with some TB cleaner and/or brake cleaner...and let it sit in the stuff for a day or so?
Just want to make sure I get this as clean as possible. Thanks!
Old Oct 15, 2009 | 08:19 AM
WW7's Avatar
WW7
Yes, the bottom plate has to come off. When you take it off there will probably be a lot of goo that can be removed with throttle body cleaner or carb cleaner. Under that plate are the channels that the air for the IAC uses so clean them as well as you can. If the gasket for this plate doesn't come with your gasket kit it can be purchased from any of the auto parts stores. Got mine at Advance Auto....WW
Old Oct 15, 2009 | 09:42 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Be sure and wet the gasket with a little motor oil before tightening to ensure an air-tight seal (vacuum leak).
I also like to use a large, plastic fruit bowl, an old toothbrush, some shop towels and an aerosol can of throttle body cleaner. Be sure and remove the Idle Air Control (IAC) motor and remove any carbon deposits on it using an aerosol can of IAC cleaner.
Do this about once a year as part of your preventive maintenance regimen. It really helps mellow the base idle, improves throttle response, and increases fuel economy, too.
Old Oct 15, 2009 | 09:56 AM
Steel Blue 91's Avatar
Steel Blue 91
I agree with all the above. As Onedef said, coat the gaskets with either a little motor oil or some high vacuum grease. Not oly does it prevent any air leaks, but makes it so much easier to take it apart next time. I use a stiff tooth brush and spray throttle body cleaner. No real need to soak the parts unless they are really nasty. Just spray on, scrub, spray off then wipe down with a shop towel.
Old Oct 15, 2009 | 10:52 AM
engle1147's Avatar
engle1147
Spray the bolts on the bottom of the IAC housing with penetrating fluid and let it work its way in there before you begin. Those bottom torx bolts are tiny and may be "frozen" in place which makes them easy to break/snap off.
Old Oct 15, 2009 | 03:11 PM
90WhiteLightning
Thanks for the info folks! This is exactly what I was looking for. I'll go ahead and spray the torx bolts and let them sit a little bit...and then take everything apart and spray and brush .
Old Oct 15, 2009 | 07:19 PM
WW7's Avatar
WW7
Originally Posted by joshwilson3
I cleaned the throttle body on my 89. Though it didn't put any oil on the gasket. It seems to run fine. How could you tell if you have a vacuum leak?
And the OEM gaskets were rubber. I wish they still made the gaskets a rubber instead of the paper.
Spray some TB cleaner around the gasket perimeter and if the idle picks up you have a vacuum leak , I didn't use anything on mine either and it sealed fine...WW
Old Oct 15, 2009 | 07:49 PM
walter schweigert's Avatar
walter schweigert
Will this same procedure work for a 1988 L98 too? I may do mine too if it will help the idle.
Old Oct 15, 2009 | 09:04 PM
impact1968's Avatar
impact1968
Ya, I've never herd of the oil trick either.
Old Oct 16, 2009 | 04:48 AM
WW7's Avatar
WW7
Yes,88 and 90 are the same.I think the oil on the gasket is so it cames apart easier next time and doesn't destroy the gasket..WW
Old May 24, 2010 | 10:53 PM
Elrick's Avatar
Elrick
what do you do if one does snap off. It just happened to me. another member said I should be able to still remove the housing because those screws snap off in the body not the threaded part. any advice would be great. thanks
Old May 25, 2010 | 07:12 AM
Elrick's Avatar
Elrick
I say it would be a pain to try and drill it out to fix it. Do you have a pic of what bolt it was? As if it was one of the bolts for the coolant passage. You could just remove the coolant hoses from the throttle body by running the heater hose straight to the front of the block.
If it is one of the bolts for the IAC passage. I guess you could just leave it broke and run a small bead of RTV or something in that area when you bolt it back up. Or you could always get a new throttle body. That's just my guess.
Thanks Josh, it's one of the small torx screw for the IAC passage. The rest of the screws feel like the y are going to snap as well. I will soak them a bit more and hope they all come out. If I can remove it from the TB, and the threads in the TB are okay I will just get a new one. seems I always have to spend extra cash
Old May 25, 2010 | 09:27 PM
screamin_conure's Avatar
screamin_conure
By chance, would anyone have/know the part number for the IAC/coolant housing to throttle body gasket for a 1992 LT1?
It would be part #63 in the diagram here: http://www.compnine.com/index.php?u=...03&grouptype=B
I've tried searching the web sites for all the big part suppliers (Rock Auto, Advance Auto, AutoZone, Ecklers, Mid America, etc.) and everyone has the gasket that goes between the throttle body and the manifold but not the one that goes between the IAC housing and throttle body. I found a TB gasket "kit" at Rock Auto, but that only has the TB to manifold gasket and not the IAC housing to TB gasket.
I guess if all else fails, I can make one from some bulk gasket material using an Xacto blade.
Thanks in advance for any tips.
Ron
Old May 25, 2010 | 10:23 PM
lostnfoundC4's Avatar
lostnfoundC4
Ron
Ron,
That diagram looks like my L98 TB. I didn't realize how similar they were.
This is what ACDelco has online for a '92 but quite different.
http://images.wrenchead.com/smartpag...US/219-607.jpg
I don't know anything about the LT1s but this is where I got my gasket kit.
Old May 26, 2010 | 09:29 AM
screamin_conure
Hah! Found it! About half way down the page. "TBI Gasket Kit".
http://catalog.oehq.com/ShopByVehicl...=True&rewrite=
Oehq.com looks like a pretty useful source for parts.
Old May 26, 2010 | 09:46 AM
Jamesnns's Avatar
Jamesnns
What are you doing now SC ?
Hey, want to hook up and have a "Dash Party" soon? I need to remove my dash again and re-wire aka: fix, my stereo connection. I "might" just go buy a better HU for it at BB. I fig we could tackle that AC button that doesn't work at the same time.
Old Aug 2, 2014 | 07:55 PM
OhioBob's Avatar
OhioBob
Anyone know where to get new throttle body screws for the clean air cover. Took mine off and they are pretty rusted. Thanks........
To Throttle Body Cleaning
