Method for testing electrical components?
Old Oct 18, 2009 | 08:32 PM
npbassman's Avatar
npbassman
Default Method for testing electrical components?
I'm preparing to put the car away for the winter and that means it's almost time to start on all of the winter projects that I have planned. The list is long and a portion of it includes a lot of items that require testing individual components on the bench. i.e. - the radio antenna, sport seat lumbar pumps, etc.
My question - what does everyone use to power these things for bench testing? It's been a little while since I've had a project car and back in the day I just used to use a battery charger with home made leads. Wondering if there are any other options out there for doing this?
Mike
Old Oct 18, 2009 | 09:01 PM
jfb's Avatar
jfb
Battery chargers don't put out pure d.c. voltage, it is full wave rectified a.c. and essentially is really bumpy d.c. . Entertainment electronics or devices with semiconductors in them don't like bumpy d.c. . You can buy regulated d.c. power supplies that put out adjustable voltage pure d.c., no bumps or battery eliminator power supplies that have a fixed output voltage, like 13.8 volts which will do everything you want to do but you have to select a power supply that can supply the current you expect to need.
Old Oct 18, 2009 | 09:35 PM
impact1968's Avatar
impact1968
If your going to take the battery out of your car during storage you could use it for short term testing, and then hook it up to your charger to top the battery back up to full charge.
The plug in adjustable power supply is the ideal solution though as you could supply 12 volts, 5 volts, etc. with the turn of a ****.
Old Oct 18, 2009 | 10:12 PM
MK 82's Avatar
MK 82
Buy a cheap motorcycle battery or take the batt out of the car and use it.
Old Oct 19, 2009 | 01:09 AM
whalepirot's Avatar
whalepirot
I almost always use a DVOM (digital volt-ohm meter) first, checking continuity, etc.. They don't load the electronic components which can cause damage, like the 'old' VOMs.
I have a regulated PS but use a battery for the more current hungry tests.
Old Oct 27, 2009 | 11:48 AM
npbassman's Avatar
npbassman
Thanks for the reply. I'm taking a look at this on on Amazon.com. That should do it, right?
Tekpower DC Variable Power Supply, 1.5-15 V @ 2A, HY152A
Old Oct 27, 2009 | 12:03 PM
engle1147's Avatar
engle1147
That will work....the amperage seem kind of low though. I'd get at least a 10. I use an adjustible linear power supply myself for most bench testing. If you don't do much bench work you might just go over to your local Wal-mart and buy a 12V rechargeable "jump pack" (~ $35). The thing will put out about 13.5 volts but that is well within the range of most vehicle electronic devices. Then go over to Radio Shack and pick up some jumpers and test probes.
Old Oct 27, 2009 | 12:26 PM
M. Schumacher's Avatar
M. Schumacher
You could use an older (pre atx) computer power supply to obtain 12vdc and 5vdc at decent amounts of current. The apple II series of computers had nice beefy supplies also. Check you thrift stores and flea markets. Probably find something for a couple of bucks.
Old Oct 27, 2009 | 12:55 PM
azrocketman's Avatar
azrocketman
Use a battery, for example, the one from the car or an inexpensive motorcyle or lawn equipment battery. This gives a smooth 12 VDC with basically unlimited current. The unlimited current can get you in trouble if you have a short (the principles of welding and resistance heating). To avoid that type of problem I'd make a test pigtail with a fuse in line. Choose a fuse value appropriate to the equipment you are testing (probably 10 to 15 amps).
I would not use a computer power supply because of their loading requirements (they are switching designs that require loading for good regulation), especially on the unused outputs, e.g. the -5 and -15 VDC lines (By the way, Apple II power supplies are not that beefy).
Steve
To Method for testing electrical components?
