RPM Chart
Old Oct 21, 2009 | 02:23 PM
dsmithh's Avatar
dsmithh
Default RPM Chart
I am interested to see if my overdrive unit is operational or not. I don't see an RPM difference with O/D on or off, and last night I was seeing 3000 RPM at 70MPH <1988 Car>. Is there an RPM chart available, or does this sound about right?
Old Oct 21, 2009 | 03:24 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Your OD is not engaging, I think I'm around 1700 at 70 mph.
http://members.shaw.ca/agent86/OverD...Electrical.pdf
http://members.shaw.ca/agent86/Overdrive-manual.pdf
Old Oct 22, 2009 | 01:07 PM
dsmithh's Avatar
dsmithh
Default RPM Chart
Originally Posted by AGENT 86
Thanks for the great information. I wonder what you think of this scenario. With the OD lamp on the Dash, I can downshift, and don't 'feel' anything slowing the car when I release the clutch. With the OD lamp off, I can downshift and feel the car being slowed by the transmission. Is there some feedback to the main transmission as to whether the OD is engaged?
Old Oct 22, 2009 | 06:03 PM
383vett's Avatar
383vett
At cruising speeds the difference between od and no od should be like night and day. Sort of like a fifth gear. If you are taching that high, it is not fuctional.
Old Oct 23, 2009 | 01:07 AM
nitronick's Avatar
nitronick
[QUOTE=AGENT 86;1571894282]Your OD is not engaging, I think I'm around 1700 at 70 mph.
To RPM Chart
