Please HELP with PKE!!!
I did the exact same thing, car didn't come with one, followed all the instructions and nothing.
Studied the FSM and followed all the possibilities and that is what it ended up being I think.
I purchased a new receiver, but I haven't installed it yet.
Laura
You can try to disconnect the battery and re-set the whole system and see if that does any good. Turn key and see if light comes on.
Chances are if the light is not coming on the PKE module is defective. If the PKE light will not come on when you try to go into programming mode, this is another indication the PKE is bad.
There is a remote chance the bulb is burned out. Pieces of the center console has to be removed to get to the bulb in the light panel (DIC). There is a detailed troubleshooting procedure that would be in the FSM. However most people with this problem wind up replacing the receiver.
There is a specific test that can be done by connecting 2 pins together in the ALDL connector. However this will not work for you because it uses the PKE light and if you can not see the light lit ever, then you can’t get the error code. And if it is dead nothing will happen anyway.
They can cost $100 to $300 depending if new or used and where you but them. The top pad on the dash has to come off the gain access. There are no good shortcuts and it will take you a day if you have never done it before. Also there is a progression of order of what comes off first to get access to the next set of screws and panels. If you are to aggressive on a 13 year old car the plastic can break real easy, be careful and using the FSM is the best way to go.
1. #26 Pke module
2. #40
3. #42
If the radio works you can eliminate #40.
Suggest you try & run diagnostics. Have you tried to do this as yet?
Alos check that the door key locks are in the vertical position & I would also check under the seats, door storage compartments & the pass/storgage compartments for a fob. Never can tell!
1. #26 Pke module
2. #40
3. #42
Also, next time you try to program the fob, when it comes time to turn the key "off"..jigggle the key in the ignition. I know it sounds silly, but another member some time found his problem in that manner.
If you want to try diagnostics, I'll pm you my e=mail. It doesn't take very long & if will just eliminate another possibility. pcolt 94 is probably right about it being the module.
And since your remote has not yet been programmed to the receiver, you could not bring it out if you wanted to. However going into programming mode does bring it out and if you can’t get the lamp to light for programming, that would indicate the receiver is bad.
