MOLD spreading under paint!?!?
Old Oct 26, 2009 | 01:25 PM
Vette_Pwns's Avatar
Vette_Pwns
8th Gear
Default MOLD spreading under paint!?!?
Okay, so I started noticing this.
On the back piece, there is some black mold-type stuff that seems to be spreading underneath the clearcoat of the car. I have a white car, so I don't know what to do.
WIll bleach kill the mold/spores while preserving the paint?
SHould I spray bleach and let it set, or spray and wipe off???
I need to do something about it because it is slowly spreading.
Old Oct 26, 2009 | 02:42 PM
ZRWHAT's Avatar
ZRWHAT
We need pics if we're going to help!
Old Oct 26, 2009 | 04:04 PM
Crepitus's Avatar
Crepitus
Defiantly need pics and info. I had a boat deveolp little blisters and seep brown fluid. Caused by a wet cover. Maby something similar?
Old Oct 26, 2009 | 04:25 PM
65747785's Avatar
65747785
I think I know what you're talking about. A clear coat chip that let moisture in between itself and the base coat white paint. The moisture spread, lifting more clear coat and never dried. Then the mold set in between the clear and base coat.
To get rid of it, cut the loose clear coat off with a razor blade (where the black mold is). Wash the mold off and that's that.
I had 2 areas on my 85 where the clear was lifting and seen water getting under it when washing the car. I cut the loose clear off. Sprayed some new clear on to seal where I cut with a razor. Once the clear was good and dry I wet sanded and polished these areas. It looks good and no more moisture getting under the clear coat.
Stop the problem now before the moisture and mold make a bigger and bigger bad spot.
Old Oct 26, 2009 | 07:25 PM
Bluewasp's Avatar
Bluewasp
NoVa Events Coordinator
St. Jude Donor '14
Old Oct 26, 2009 | 07:33 PM
Vette_Pwns's Avatar
Vette_Pwns
8th Gear
I'll see if I can post some pics up soon to show you guys.
Old Oct 27, 2009 | 01:16 PM
engle1147's Avatar
engle1147
If it is a "true" black mold that chlorine treatment might not do the trick
To MOLD spreading under paint!?!?
