Lights
Old Oct 28, 2009 | 05:55 PM
shamdave's Avatar
shamdave
Default Lights
I have an odd one My fog lights and interior lights come on and my bell dings any body got any ideas.
Old Oct 28, 2009 | 09:13 PM
pcolt94's Avatar
pcolt94
Ok Dave sounds like quite a strange one. But give us a little more. Does it happen by itself, all at once, and what triggers it to happen.
I can see the door switch affecting the bell and the interior lights, but not the fog lights.
Old Oct 29, 2009 | 07:24 AM
shamdave's Avatar
shamdave
Sorry when i put on the brakes they all come on at once
Old Oct 29, 2009 | 11:31 AM
pcolt94's Avatar
pcolt94
Is this trick, or treat cause its near Halloween, or is that car just possed and in need of a exorcism.
Off hand I could not even venture a valid guess. It almost sounds like a grounding problem but I think that might also be a stretch. However the way I would approach it is to target in on only one of the items. Find the one easiest to work on and access. And by using the FSM drawings I would find a link between any brake wiring either hot or return wiring and the item you are going to resolve first.
Old Oct 29, 2009 | 12:32 PM
94vettelover2's Avatar
94vettelover2
Could be headlight switch causing fog light/interior light issue-check connector that goes into headlight switch for melting of connector or burnt wires.Could be cut in a power wire(brakes) thus supplying power to fog light etc.Disconnect brake switch & see if same problem exists.
To Lights
