Ticking caused by throttle body gasket
St. Jude Donor '10-'11
The car idles low and stalls. I replaced the gasket and it has been nothing but trouble since. I do believe the gasket is loose because it makes a tick tick tick sound. Last time it did that, I had a hole in my exaust manifold. It sounds just like this ticking and no, it's not the injectors. Could a bad gasket cause that or no?
Just for records, the TPS is NOT the problem. Ask me how I know.
A throttle body gasket that is loose or leaking will not tick. As you discovered, a leak in the exhaust will tick. On the intake side, you will often get a whistle and an increased idle speed.
