Question for the technical folks.
Old Nov 14, 2009 | 07:41 PM
  #41
RoperC4's Avatar
RoperC4
This car is a nightmare...it might get parted out or sold really cheap...
Old Nov 14, 2009 | 09:21 PM
  #42
RoperC4's Avatar
RoperC4
Would a bad "crankshaft positioning sensor" do this?!?!
Old Nov 15, 2009 | 01:08 AM
  #43
gbrtng's Avatar
gbrtng
Just read your story and saw that some codes are being set in the ECM. This sounds suspiciously like my wife's 91 L98 car - acted similar and after throwing parts at it, it was the ECM. They are not 100% reliable, and hers was randomly setting 3 unrelated codes.
I found one at a local junkyard and it was an AC Delco rebuilt. The 91 part crosses to about 10 other GM vehicles, and with a little luck you can find a used one to try instead of buying a rebuilt at full price. Good luck.
Old Nov 15, 2009 | 04:59 AM
  #44
toptechx6's Avatar
toptechx6
Not likely since your 93 does not have one.
Old Nov 15, 2009 | 10:25 AM
  #45
RoperC4's Avatar
RoperC4
Good to know.
Old Nov 15, 2009 | 10:26 AM
  #46
RoperC4's Avatar
RoperC4
Ive already went the new ECM route and nothing changed...
Old Nov 15, 2009 | 12:03 PM
  #47
RoperC4's Avatar
RoperC4
Whats the difference between that and the "crankshaft sensor" in my FSM?
And once again, could that be the problem by chance?
Old Nov 15, 2009 | 01:36 PM
  #48
RoperC4's Avatar
RoperC4
Its the optispark isnt it!?
Old Nov 15, 2009 | 03:16 PM
  #49
jtc44's Avatar
jtc44
Default car dies
No vette tech am I. When car dies Will it crank? if bat. should be ok If it cranks does it get spark? and fuel? does radio loose it's memerey? This trick may help can you get to wires comming of ing. sw? or fuel pump relay ing coil? If so tap into wires one at a time go to a LED in car to grnd. When car dies are the led,s lit or out? This may help you to get to prob. Also get a frac. elec. book also I have seen relays come and go at will and good luck!!
Old Nov 15, 2009 | 04:15 PM
  #50
RoperC4's Avatar
RoperC4
I do not lose any radio stations. Engine will immediately crank right away but just will not start, it does indeed get fuel but no spark.
Old Nov 15, 2009 | 05:17 PM
  #51
STL94LT1's Avatar
STL94LT1
Yes.
Old Nov 15, 2009 | 05:47 PM
  #52
RoperC4's Avatar
RoperC4
Originally Posted by STL94LT1
Yes.
Any way for me to know 100% before going down this road?
Old Nov 15, 2009 | 05:58 PM
  #53
STL94LT1's Avatar
STL94LT1
You should be getting code(s) 16/36 for a bad opti.
I would pull the Crane HI-6tr ignition and see what happens.
Old Nov 15, 2009 | 06:33 PM
  #54
RoperC4's Avatar
RoperC4
Am not getting those codes... Could it be my crankshaft sensor?!
Old Nov 15, 2009 | 06:36 PM
  #55
STL94LT1's Avatar
STL94LT1
On pre-96 cars the opti is used as a crankshaft sensor. Most of the time if an opti is bad, it will throw a code.
Old Nov 15, 2009 | 06:45 PM
  #56
RoperC4's Avatar
RoperC4
Im sorry and I dont mean to sound like I am arguing because I need the help please, but my FSM here clearly shows a picture of the side of the block and labels #1 as CRANKSHAFT SENSOR.
Is it misleading me or is there a difference i am unaware of?
Old Nov 15, 2009 | 06:57 PM
  #57
STL94LT1's Avatar
STL94LT1
It's very misleading and incorrect. The only sensors on the side of the block are knock sensors and an oil temp sensor. Are you looking at a FSM for an LS1 or your 93?
To Question for the technical folks.
Old Nov 15, 2009 | 07:03 PM
  #58
RoperC4's Avatar
RoperC4
These
Old Nov 15, 2009 | 07:09 PM
  #59
STL94LT1's Avatar
STL94LT1
Well, I'm surprised you got that information from the 1993 FSM. But, it is wrong. Could you scan a picture/illustration?
Old Nov 15, 2009 | 07:10 PM
  #60
RoperC4's Avatar
RoperC4
So...I dont get any codes for an opti though...
