Scanner
Old Nov 8, 2009 | 07:01 PM
Bulldog Steve's Avatar
Bulldog Steve
Default Scanner
Have a 1990 and want to buy a scanner or a program to check for codes and see what the systems are doing can you guys point me in the right direction.
Right now i have a service abs light on and have the fsm but it wont pull and codes with the paper clip. I forgot about the the scan and tune section i also have a post in tech.
Steve
Old Nov 10, 2009 | 09:48 PM
DBall's Avatar
DBall
Download the datamaster program and get the ALDL cables with a USB plug from Andrew Mattei at AKM cables or Gary at TTS systems from Datamaster. Good info and you get 20 free scans before the $85 lifetime software charge. It works great on my mod L-98 383 which DOES need a tune with 30 lbs injectors, etc, etc. They will help you a great deal. Good luck.
Old Nov 10, 2009 | 10:14 PM
Bulldog Steve
Is it datamaster.com
Steve
Old Nov 11, 2009 | 07:24 AM
rodj's Avatar
rodj
http://www.ttspowersystems.com/DataM...downloads.html
You need the DM35x8D file
ALDL to USB cable here $60
http://www.aldlcable.com/
Also considerr TunerPro RT ; unlimited datalogs
http://tunerpro.markmansur.com/downloadApp.htm
You download TP program ;
then download the two files (Bin Definition and ALDL Definition ) relevent to your vehicle (ECM # 1227730 )
http://tunerpro.markmansur.com/downloadBinDefs.htm
To Scanner
