C4 of Year Winner (appearance mods) 2019
Originally Posted by RED-85-Z51
Anyone know a good way to figure compression ratio?
Static compression can be figured using this SCR calculator. But it's better to understand and calculate DCR using the one you can download on this webpage.
The Speed-0-Motive article is good too, but I was surprised to find that it's been pieced out on the KB-Silvolite website. (And, I thought their engineers wrote it!) HA!
Seriously, there are two statements I feel should be qualified in the Speed-O-Motive article: The obvious one is where they suggest running lower thermostats to aid in the prevention of detonation. Since this forum is so smart, we ALL know it's going to take a bigger radiator/water pump to cool things down on 100-degree days. :-)
The other point is that dish pistons (in general) may not help quench as indicated. IMO, they forgot to qualify that statement. Notice early in the article quench is defined as the flat part of the piston that would contact the head at zero quench/clearance. With a true dish, it's face can be totally recessed -- meaning there'd be no real quench area. To follow the advice correctly, choosing a (dish) piston that's at least flat on the outside of the valve reliefs. An inverted dome would be a good example...or a stepped dish.
Zero decking is not a problem....but piston choice (flat top, dished, domed, or multiple reliefs) can give you what your after with out the machine work. Just pick your parts and do the compression calculations for the all the parts working together as the others have suggested.
Figuring in the Pistons Ive got picked out, the heads, the head gasket, and the given boreXstroke size of a 350sbc...it gives me a compression ratio of 10.46:1
