Help needed diagnosing/repairing cruise control
Old Nov 18, 2009 | 04:05 PM
Fast Doc's Avatar
Fast Doc
Default Help needed diagnosing/repairing cruise control
I have a 1996 LT-4 Roadster with 30,000 miles on it. This morning the cruise control worked poorly, did not hold speed accurately. On the way home from work it failed all together. I checked the fuse, hoses, and actuator cable and they all look good. Where do I go from here in diagnoising and repairing this item? The clutch and brake pedal switches also seem normal.
FWIW this happened about a year ago and 'fixed' itself.
Thanks for the help guys!
Old Nov 18, 2009 | 04:54 PM
aminnich's Avatar
aminnich
I spent a ton of time diagnosing mine using the FSM and followed all of the procedures only to find out the brake switch was faulty. What I did learn is the module is an absolute PITA to get to, plus they rarely go bad. Brake switch is easy, relatively cheap and likely the cause.
Old Nov 18, 2009 | 05:46 PM
Fast Doc's Avatar
Fast Doc
The brake lights function normally. Is there another switch on the brake I need to check?
Old Nov 18, 2009 | 05:55 PM
CorvetteMike2024's Avatar
CorvetteMike2024
Corvette Enthusiast
Default Vette
JMO...............Vacuum leak.
Old Nov 18, 2009 | 06:39 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
In this case, I don't think so Mike.
My LT4 does this from time to time also. You can be driving down the interstate with cruise on, and it just shuts off (exactly like it does if you tap the brake or clutch).
It only does this once in awhile. When it happens, just wait a second and push the set button and it works again.
If it was vacuum, wouldn't it act up a little differently?
I can go for months without any issues at all. That's probably the reason I haven't even looked in too this issue. It happens so rarely, I haven't looked in too it.
Old Nov 18, 2009 | 08:35 PM
engle1147's Avatar
engle1147
http://forums.corvetteforum.com/c4-t...-for-94-a.html
Old Nov 18, 2009 | 08:44 PM
pcolt94's Avatar
pcolt94
In this case
I spent MANY hours of time over a couple of weeks of work and testing. I went further than most might have gone. It turned out to be that switch assembly.
Check my post a decide for yourself.
Old Nov 18, 2009 | 10:45 PM
Fast Doc's Avatar
Fast Doc
OK, couple of questions.
I appreciate the link to the other thread.
Could it still be the switch and my brake lights function normally?
I looked under the dash at the brake pedal, and holy cow is it tight in there! Where's the switche(s)? Do you need to train a chimp to get under there or can a 6'1" 45 year old get to it?
I don't see a tear in the vacuum actuator. If I need to test it, how do I do so? I have a handheld vacuum pump/tester.
The connections to the actuator are clean and seem sound.
Nothing works in the cruise system, neither the set nor accelerate position.
I really rely on the cruise to help keep me from getting too many tickets!
Old Nov 18, 2009 | 10:48 PM
Fast Doc's Avatar
Fast Doc
It looks like one switch body but two sets of contacts, one for the brake lights and one set for the cruise. Am I understanding this right? How do I teleport the switch out and onto my workbench?
Old Nov 18, 2009 | 11:54 PM
pcolt94's Avatar
pcolt94
The whole switch assembly is held in where the plastic on the edges snaps into the bracket. A bit nerve racking prying it out with a screwdriver, but did it carefully. One plug on one switch assembly, and one hose on the other assembly (no electrical).
The electrical switch assembly has 3 sets of contacts in it and all are independent circuits. One for brake lights, cruise and TCC lock up. I took all out and cleaned them up.
My vacuum hose had a coupling 6 inch back from the switch so it was easy for me. But I could not get the hose off the actual vacuum switch assembly by pulling it.
I am a lot smaller than you and have no problem laying under the dash getting my feet in the air. But I can see where a big guy might have a problem.
Old Nov 19, 2009 | 09:21 PM
Fast Doc's Avatar
Fast Doc
Thanks. I think that's where I'll start but is there a way to test the switch with a voltmeter/ohmmeter remotely from the connector on the vacuum servo perhaps?
Old Nov 19, 2009 | 10:26 PM
pcolt94's Avatar
pcolt94
No, there is no easy way to check the switch. The wires run back to the cruise module on the passenger side. Getting to it is a huge effort as you can see the picture in my post. I measured my switch remotely several times and it checked good. I could do it because I had the module out a the time. An then it finally checked bad and I caught it.
The switch seems to go bad on a slight marginal basis. Does not always show bad till a current runs thru it. That is why all these cruise problem are intermittent come and go problems.
Old Nov 19, 2009 | 10:46 PM
Fast Doc's Avatar
Fast Doc
Thanks for taking the time to help me out. I'll pay it forward to be sure. When I get back from my conference I'll dig into it.
I'm recovering from a motorcycle accident and my hands and knees are still busted up so it's a bit hard for me to get in there. Even if I can't do it in my current state I can at least tell the shop where to start and that would still save me time and money. Hopefully!
Old Nov 21, 2009 | 11:00 PM
grinditout's Avatar
grinditout
I have all the parts out of my 96 cruise control system, servo , module , switch & pigtail.. could sell you some parts.
All of it for $50 + shipping.
Old Nov 22, 2009 | 07:33 AM
bad-zr1's Avatar
bad-zr1
Since you have a LT4 don't forget to check the switch on your clutch pedal also. It will disable the cruise the same as the brake switch does.
Old Nov 22, 2009 | 10:18 AM
pcolt94's Avatar
pcolt94
Excellent information. This point has got past many of us due to thinking automatic to much. I will make sure to include this in my future advice.
Old Nov 22, 2009 | 10:50 AM
engle1147's Avatar
engle1147
Right on!
To Help needed diagnosing/repairing cruise control
