IAC and idle problem
Old Nov 24, 2009 | 10:31 AM
engle1147's Avatar
engle1147
Originally Posted by btr85vette
Are you talking about moving the blades farther away from the bore, so they're not inside the bore?
Was talking about turning the idle set screw a turn or 2 to allow some (minimal) air to pass through the TB bores at idle (closed throttle).....read SUNCR's post his explaination is much better and includes the fact that additional air should be provided other than what just the IAC provides....Your 85 FSM will have a pretty good description of what is involved. Once you get the idle air screw set you shouldn't need to mess with it again....the computer should take over idle by way of the IAC metering.
Old Nov 24, 2009 | 01:13 PM
SunCr's Avatar
SunCr
Using IAC counts to set minimum idle isn't precise and though that information is nice, a functioning system simply moves the IAC to whatever number that gets it within Targeted and that number can vary by engine, make and model. Get it wrong and idle quality, tip in acceleration can/will suffer.
A throttle body that you have to take a Dremel or Drill Press to isn't worth the money - just my opinion - but speaking of which, make sure the IAC Pintle fits - there are different sizes - reputable aftermarket manufacturers should know what works and have a live person you can talk to.
Old Nov 24, 2009 | 09:45 PM
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
Originally Posted by aklim
He did say that he has seen it extend and heard it so I am not sure that it is non functioning.
You can apply voltage to it and it will move. But, if one of the 4 wires isnt working, it may not go in and out during operation.
You can tell the IAC what to do, but you cant see what it is doing, as GM doesnt have that figured into the ECM datalogging for some reason. You either OHM it or replace it with a known good one, and see what happens
Old Nov 25, 2009 | 09:06 AM
aklim's Avatar
aklim
Damn. Should have remembered that. I had a broken IAC wire. See the IAC counts and no effect.
Old Nov 25, 2009 | 09:40 AM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
I just centered the throttle blades in the bore, and tightened the screws. I did not change anything really, just made the original throttle blades move to a .002"-.003" movement.
Old Nov 25, 2009 | 02:07 PM
btr85vette's Avatar
btr85vette
I did everything that SunCR said above, and...
Same bad idle.
To recap, this is what I've done so far:
1) Checked TB and IAC housing. TB is basically new, IAC housing looks good. Put in new gaskets.
2) Checked IAC out of the car. Pintle extended correctly when ALCL grounded.
3) Checked IAC connector with ALCL grounded. Power to all 4 plugs.
4) Checked IAC on car, with ALCL grounded. Can hear buzzing from IAC motor.
5) Performed idle procedure from SunCR.
6) Car still idles around 500 RPM, which is what I set with IAC unplugged according to procedure.
6) With car warm, can remove IAC with no difference in idle RPM.
Is there any way to check the IAC with the car running without a scanner? I've checked the IAC every way the FSM says and it appears to be good. IT JUST DOESN'T WORK!
Old Nov 25, 2009 | 03:07 PM
tequilaboy's Avatar
tequilaboy
Target idle speed for an 85 auto with warm coolant in gear is 550 rpm. +50 rpm offset for park or neutral.
If it will maintain target idle speed with and without the A/C on, I'd say the IAC is working.
If the tps voltage at idle is too high, closed loop idle PID control will be disabled and the IAC position will be based instead on the warm park position table (coolant temperature dependent) and throttle position without regard to the actual or target rpm.
Check the idle in gear, in park or neutral and with and without the A/C on (if it still works) to verify idle speed in the 550-600 rpm range.
It sounds like you're setting the min air close to the target rpm and therefore not seeing much of a change with the IAC connected.
Old Nov 25, 2009 | 03:26 PM
cumbercr's Avatar
cumbercr
Forgive me if I send you in the wrong direction. The IAC has two coils, one extends the pintle and the other retracts it. You said you verified the pintle extends. The pintle needs to retract to increase RPM. Is this a new IAC? It is possible one coil is bad and you were able to get it to idle by adjusting the idle screw to increase flow through the throttle blades.
Old Nov 25, 2009 | 03:30 PM
btr85vette's Avatar
btr85vette
It is a brand new IAC. I checked this one and the old one, and they both extend the pintle.
I've also checked both coils and they are both around 55 ohms.
Old Nov 25, 2009 | 10:49 PM
coupeguy2001
If the IAC has set the idle, disconnecting the connector won't change the idle.
turning on the A/C will cause the engine to die when disconnected if already idling.
putting it in gear may have the same result if idling with the IAC disconnected.
If nothing happens when you turn on engine loads means the IAC is doing it's thing.
If the Idle is too low, you have to redo the idle sequence again, and maybe try to be as accurate as possible.
Old Nov 27, 2009 | 02:02 PM
rons85's Avatar
rons85
Just a coupe of thoughts..
I also have a BBK TB on My '85, for about 4 years now. When I first installed it there was an "interesting" clearance issue between the throttle shaft and the throttle position sensor - the retaining rivet in the TPS was hitting the end of the throttle shaft, and although Both should be rotating together it caused a binding that prevented the TB from closing at idle. A different brand of TPS fixed it, some TPS manufacturers apparently use different dimensions for the protrusion length of the device, either that or there Is no specification for it..
Also - the BBK TB's are known to have a casting issue where the "finger" or hook on the TPS will rub on the side of the TB casting causing the TPS to stick, and not return from wherever you opened it up to last/furthest. The Throttle blades WILL return fine, just that the TPS lever will be stuck and not follow. This will drive you nuts if you don't see it - the ECM never knows that the Throttle came back closed. It's obvious if you are looking at a scan tool, of it you Look at the operation of the TPS itself. I had to grind clearance on My BBK TB to fix this, it happened to me!
Old Nov 27, 2009 | 02:51 PM
steve40th's Avatar
steve40th
Do you have the factory throttle body, if so put it back on and see what happens.
