How Do I remove the battery ?
Old Nov 27, 2009 | 02:44 PM
Batman0913's Avatar
Batman0913
Default How Do I remove the battery ?
I just purchased my 1st Vette 84. The battery is old.
How do I remove it ?
Do I have to remove the cruse control or side panel ?
Thank you !
Batman0913's Avatar
Batman0913
Thank you !
Old Nov 27, 2009 | 03:01 PM
rementis's Avatar
rementis
Open the rear hatch, have a car-knowledgeable buddy jump in the back. Put a nice looking girl in the passenger seat, they are fun to have around. Drive the car to Wal-Mart, and have your buddy watch them replace the battery, so he'll know how to do it next time. LOL, just busting on you dude. Congrats on getting a vette, there's just nothing else like them. If you search on this forum you'll find a thousand posts about changing the battery out.
Old Nov 27, 2009 | 03:02 PM
dontruitt's Avatar
dontruitt
Here is an instruction set for removing the battery. It worked for my 1987. Hope it helps. you are basically removing the "gill" panel beside the battery.
http://www.corvettemagazine.com/2001...ttery/bat1.asp
Old Nov 27, 2009 | 04:11 PM
Muffin's Avatar
Muffin
OK, I'll be the first. If you have and inkling you will keep the car or do any maintenance yourself, go to that famous auction site and buy a Field Service Manual. You can do very little without it. Yes, it will pay for itself on its first use.
Old Nov 27, 2009 | 04:29 PM
redrose's Avatar
redrose
that article is FOS...after removing gill panel screws at frt wheel opening and one 10 mm bolt at rear top of gill pnl, on 85+ no need to remove rocker panel screws, just reach into gill pnl/rocker joint with 10mm open end wrench and loosen the bottom bolt (the gill panel is 'slotted' at that 'hidden' fastener only, for 85+)...84's are not 'slotted' oem and have a hole at that fastener.
Old Nov 27, 2009 | 05:13 PM
Batman0913's Avatar
Batman0913
COOL !
Thank You !
All for your help !
To How Do I remove the battery ?
