Radiator Problem Please HELP!!!
Old Dec 5, 2009 | 04:01 PM
My1st's Avatar
My1st
Default Radiator Problem Please HELP!!!
Does anybody have a remedy for this? I had to drain some fluid out of the radiator to add fresh Anti-Freeze and now the drain plug will not seat enough to hold the fluid back (Threads must be stripped in the radiator the plug threads look fine). I tried putting plumbing pipe tape on the threads but it didn’t work.
Old Dec 5, 2009 | 04:10 PM
nutz4c4's Avatar
nutz4c4
Did you pull the "plug" right out of the radiator? I believe there is an oring seal,maybe it fell off
Old Dec 5, 2009 | 05:01 PM
samsonb's Avatar
samsonb
You can get a replacement from the dealer, or at Autozone.
Old Dec 5, 2009 | 06:13 PM
My1st's Avatar
My1st
All I did was unscrew the plug, the rubber washer is still attached to the plug. It appears the threads in the radiator may be stripped or the plug itself, darn plastic parts.
I went to the local Autozone and bought a new plug but I’m not sure it will work. The one I removed has threads that screw into the radiator and the new one it appears you push it in and turn it to lock in place. I wouldn’t have bought it but I know the hole in the radiator is elongated as is the new plug is so I’ll give it a shot tomorrow, hopefully it will work.
Old Dec 5, 2009 | 11:33 PM
samsonb's Avatar
samsonb
I believe the one I picked up was pretty much the same thing as what was in the radiator. It screwed in like OEM. Also, it should come with a new nut that the plug screws into that you put in the radiator. I didn't really need the nut part as the new plug screwed into the existing nut that was already in the radiator.
But anyways, when you do loosen that screw to drain coolant, you don't need to pull it all the way out.
Old Dec 6, 2009 | 09:52 AM
jhammons01's Avatar
jhammons01
Zactly, when you open that thing, just let the coolant drain. It only takes a full turn or so......
Old Dec 6, 2009 | 10:08 AM
engle1147's Avatar
engle1147
that sucks. For next time, just pull the lower radiator hose.
Old Dec 6, 2009 | 06:03 PM
My1st's Avatar
My1st
Well I finally got it fixed. As I suspected the threads on the plastic insert in the radiator were stripped. Had to pull the radiator to get access to it outside in 20 degree weather. Boy that was fun! Got a little scarred though, I think the threads may have stripped for the lower transmission cooling line. The flange on the tubing didn’t want to turn very easily to get it started in the hole and once in it felt like it stripped. Thank god it didn’t leak after warm up and in and out of gear several times.
To Radiator Problem Please HELP!!!
