speedo
Old Dec 6, 2009 | 11:35 PM
cowmags's Avatar
cowmags
Navigator
Default speedo
just installed a 373 rearend in my car to replace the origanal 259,what do i need to do to get my speedometer to match the change of gears?i no it's not right when i am hanging with cars doing 55 and my speedometer is showing 85.is there something i need to install to make up the difference?
Old Dec 7, 2009 | 04:16 AM
toptechx6's Avatar
toptechx6
It depends on the year of the car and since you have NOT supplied that information or filled out your profile it is not possible to provide a correct response.
Old Dec 7, 2009 | 09:41 AM
cowmags's Avatar
cowmags
Navigator
My bad. I have a 1993 C4. From what I understand - there is a gear change possible in the transmission? Thanks for the help!
Old Dec 7, 2009 | 10:22 AM
CFI-EFI's Avatar
CFI-EFI
Correct. You will need to change your red, 17 tooth, drive gear for a grey, 15 tooth, drive gear, part number, 8642620. The orange, 35 tooth, driven gear will have to be changed for a light blue, 45 tooth, driven gear, part number 25513052. You can probably rotate the VSS 180° to make it fit, but the part number for the correct VSS is 10456092.
RACE ON!!!
Old Dec 7, 2009 | 01:30 PM
Scrrem's Avatar
Scrrem
When you change your drive gear on the transmission shaft, don't let that little retainer clip fly when you are removing the old gear. Mine came shooting out of the opening for the VSS and went halfway across the garage.
Scrrem
To speedo
By Michael S. Palmer | 2026-06-03 11:00:24
