Intercooler supercharger?
Old Dec 14, 2009 | 05:30 PM
94vettelover2's Avatar
94vettelover2
Originally Posted by Kool88vette
If I was in a different state I would do the heads, cam and longtubes. California banned methanol injection so I'm also limited on supercharging. A few people warned me that I could blow the engine because the stock pistons won't hold up very long.
I should probably move.
Want to trade places for awhile.By the way my sidewalk needs to be shoveled.And its 5 degrees out.And the roads here a crap.And theres salt everywhere.Did I mention my corvette is in storage
Old Dec 20, 2009 | 08:23 PM
philipneeper's Avatar
philipneeper
Cruising
so if you add a supercharger to a 91 vette with a l98 i need to retune my engine? what if i have a performance chip from hypertech or jet performance... im new to this forum .. hi im philip.. currently in iraq just bought a 91 vette.. thinkin about a few upgrades any advice would be grea thx guy
Old Dec 21, 2009 | 09:16 AM
TheCorvetteKid's Avatar
TheCorvetteKid
Yes, a retune would definitely be needed after a supercharger install. And no, an off-the-shelf chip like a Hypertech or Jet won't cut it. That doesn't mean the engine won't run... it just means it won't run properly.
Most good supercharging kits will come with a replacement EPROM, but these are programmed on the "safe" side, meaning they tend to run the engine rich to avoid detonation and pinging. More often than not a retune is still going to be required to optimize everything. But any good experienced shop can do that without much cost or effort.
Old Dec 21, 2009 | 10:48 AM
AKS Racing's Avatar
AKS Racing
The bolt on kit manufacturers (ProCharger, Vortech) recommend to use the factory chip when running their products. They are very clear in the instruction manuals to detail that you are not to run the "off the shelf" chips (i.e. Jet, Hypertech, etc.) as they all add timing and fuel which may be detrimental to the life of your engine with their supercharger package.
Old Dec 21, 2009 | 11:16 AM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
Vortechs come with an FMU
I'm not using on one mine, instead I'm retuning it.
I couldn't use a stock chip as I'm also adding AFR heads, a cam, and a stroker short block.
Don't do this unless you find someone that knows what they're doing.
I'll be using water injection, not meth.
Has California banned that as well?
Old Dec 21, 2009 | 11:35 AM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
Soon , they raised the prices and put a limit on each household.
Old Jan 16, 2010 | 02:13 AM
pologreen1's Avatar
pologreen1
So could a factory chip be tuned more?
