Emergency brake doesn't work 86
Old Dec 16, 2009 | 06:42 PM
Elrick's Avatar
Elrick
Default Emergency brake doesn't work 86
When I pull up the e brake handle it just comes right up, no clicking sound ,no resistance, and the handle will just go back down to the floor. I have no experience with e brakes, what should I be checking or looking for. Is it a connection in the handle or a connection back at the drum in the wheel? Is this a complicated system? I have been driving the car like this for months which is probably not the greatest idea. I have replaced the master cylinder, front rotors and pads and put in steel brake lines up front. I would hate to pay a garage to fix this if I can do it myself but I don't know what I am doing. I know I did all the other brake parts correctly but it still freaks me out a bit when I am tearing down the highway without an e brake and the knowledge that I am the in-experienced, rookie wrench who put in the brakes that I do have. also, on my control panel the BRAKES sign is always lit up. How do I clear that if and when I fix the problem? Thanks
Old Dec 16, 2009 | 06:59 PM
94z07fx3's Avatar
94z07fx3
It is either the ratcheting mechinism or a break in the cables.
You will have to diagnos a bit further.
If you were to move the hadle while holding the cable under the car you'd know for sure.
The cables are hard to come by. But they can be made up out of generic parts. The Lever and the ratcheting bit are always available from the catalogs new or from the recyclers like Vette2Vette.
The brake light is likely being lit by the contacts being closed inside the e-brake hadle housing.
Old Dec 16, 2009 | 07:30 PM
Elrick's Avatar
Elrick
Thanks for your help. Do the original brake shoes usually hold up pretty good?
Old Dec 16, 2009 | 08:21 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Climb under and have a look to see if there any breaks in the cables. If all looks good, have someone pull the handle and watch the cables. If that's all working, adjust them per the FSM.
http://members.shaw.ca/agent86/Parki...Adjustment.pdf
Old Dec 16, 2009 | 08:34 PM
Harsh20's Avatar
Harsh20
my E brake was doing the same thing. I just pulled the cover off of the mechanism beside the seat and sprayed it with wd 40 while pulling the brake up and down until the button released and started working again. took about 8 minutes. to get the cover completely off you need to take the seat out but just set the seat all the way back and take out the top screw and pry the top of the cover back some and spray a little and work the brake while pressing and releasing the button.
Old Dec 16, 2009 | 08:45 PM
94z07fx3's Avatar
94z07fx3
I've never had a Vette with the shoes inside the rear rotors. But I understand that unless the shoes are allowed to drag that they should last a very long time.
Old Dec 16, 2009 | 11:05 PM
383vett's Avatar
383vett
The E brake mechanism is all mechanical and actually pretty simple. Put the car on jackstands, crawl underneath and have someone pull up on the handle. The cable is easily seen underneath the car. See if it moves. If it does, follow it to the back wheels and see if the linkage there moves. If it does, adjust the cable as previously suggested. If that doesn't do it, the shoes can be adjusted. If that doesn't do it, check the shoes, they may be worn out. If the cable doesn't move at all, it is probably disconnected from the handle. Look and see what's going on.
Old Dec 16, 2009 | 11:42 PM
pologreen1's Avatar
pologreen1
very simple set up.
Old Dec 16, 2009 | 11:56 PM
dogfish246's Avatar
dogfish246
If the brake works when you pull it up, and your problems is the fact that it wont stay engaged when you release it, 99% of the time a little WD40 will do the trick. Just take off the ebrake cover and spray some wd40 onto the moving parts until you get the ratcheting sound and you brake stays engaged
That was my problem about a month ago, and thanks to these fine forum members it was easily resolved and now the parking brake works great!
Old Dec 17, 2009 | 09:24 AM
markKlein's Avatar
markKlein
The handle is supposed to drop back down, do not expect it to stay up.
Old Dec 17, 2009 | 11:12 AM
Elrick's Avatar
Elrick
Thanks for all the replies. As usual the knowledge here is incredible. I would not be able to own this car without the help from all of you forum members, it would be way to expensive. I am a bit laid up from back surgery now so jacking up the car and really getting into it is a bit tough. I will post the outcome as soon as I can. I was just about ready to bring it too a garage and get hosed but it sounds like I can manage this. Thanks again everyone, have a great holiday. also, I finally figured out how to get pics into my album so check them out if you get a chance so you can see where all your advice has led.-E
Old Feb 21, 2010 | 12:55 PM
Dave C's Avatar
Dave C
I'm new to the C4, my "new to me" 1986 Z51/4+3 got delivered yesterday, I need to adjust my parking brake as my driveway in pretty sloped - the link to the adjustment procedure above is not working, any other pointers?
Dave
74 L82 Covertible (sold)
67 Plymouth GTX
86 Z51 Coupe, 4+3, 63k miles, original everything
Old Feb 21, 2010 | 01:13 PM
Dave C's Avatar
Dave C
Nevermind - found it...
http://forums.corvetteforum.com/c4-g...djustment.html
Old Feb 21, 2010 | 03:02 PM
DBo's Avatar
DBo
I had the same problem with my 84 I bought back in September, and the fix was simple: the cable had slipped off the lever/actuator coming out of the brak drum. Put it back on and that was that. Holds very tight. Dave
Old Feb 21, 2010 | 06:39 PM
76LS1BIRD's Avatar
76LS1BIRD
Is there a writeup on how to replace the ebrake shoes ?
Thanks Dale
Old Feb 21, 2010 | 11:06 PM
kenv's Avatar
kenv
From: levittown pa. usa Even a bad day with my `Vette, is better than a good day at work
St. Jude Donor '10
Dave
67 Plymouth GTX
Dave C, Nice looking car. Post up some more pics. I like the avatar, I used to have a `69 Roadrunner. Wish I still had it.
Old Feb 22, 2010 | 09:23 AM
AGENT 86's Avatar
AGENT 86
Thanks Dale
http://members.shaw.ca/agent86/Parki...20Assembly.pdf
To Emergency brake doesn't work 86
Old Feb 22, 2010 | 07:59 PM
76LS1BIRD's Avatar
76LS1BIRD
Thank you.
Old Feb 23, 2010 | 06:53 AM
Dave C's Avatar
Dave C
I'll post some pics of my "new" C4 on an intro post as a newbie to the group, I've been a member over on the C3 side for a couple years with my old L82 'vert... don't want to hijack the thread... see ya!
Dave C
74 L82 'Vert (sold)
67 Plymouth GTX
86 Z51/4+3 Coupe (Original, 63k miles)
Old Feb 23, 2010 | 10:29 PM
Clark Bente's Avatar
Clark Bente
KenV-
69 Roadrunner was the best year ever. Those inward canted tail lights - wow!
Check out this week's Autoweek. Featured article on Don Prudhomme's '70 Cuda HotWheels funny car.
He's still got it - completely redone as it was. He found and restored the original transporter as well. I just saw it on JayLeno's Garage website, and here it is again in Autoweek. Thought you'd appreciate it as a Mopar person from back in the day.
By Michael S. Palmer | 2026-06-03 09:39:05
