Favorite RTV
Old Dec 23, 2009 | 07:09 PM
cshuman's Avatar
cshuman
Default Favorite RTV
OK, what brand and type do you guys like to use for the head bolts and intake?
Old Dec 23, 2009 | 07:12 PM
Pete K's Avatar
Pete K
I use permatex liquid teflon, and have never had a leak.
Old Dec 23, 2009 | 07:15 PM
aboatguy's Avatar
aboatguy
A couple of years ago Ron at AI sent me a tube of GM teflon sealant and I've been using that tube ever since.
The right stuff on china walls
Last edited by aboatguy; Dec 23, 2009 at 07:34 PM. Reason: THought question was just bolts
Old Dec 23, 2009 | 07:16 PM
cshuman's Avatar
cshuman
Even on the ends of the intake manifold?
Old Dec 23, 2009 | 07:22 PM
Pete K's Avatar
Pete K
Bolt threads only.
I lube the bottom side of the bolt head with a thin smear of ARP bolt lube to reduce friction, and get more accurate torque readings. For the ends of the manifold, my silicone of choice is Ultra Copper.
Old Dec 23, 2009 | 07:58 PM
Aardwolf's Avatar
Aardwolf
I also like the ultra copper. I've been using that for a long time, ten years or more. It works well but can be very noticeable for some intakes. Keep some black around if you want it to blend in, like on the SR lid. I don't use the right stuff product anywhere.
The head bolts this time around I tried loctite head bolt paste. My engine had bad blow by and I found that all the gas in the oil dissolved most of it on some of the bolts. I'm not sure if other products would fare better or not. I usually have my engines fail by breaking the crank or spinning a bearing so this is new having one wear out.
Old Jan 8, 2010 | 08:15 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
The Right Stuff by Permatex®.There is no substitute!
Old Jan 9, 2010 | 09:50 AM
HlhnEast's Avatar
HlhnEast
Black high temp silicone. It just looks better than blue or copper. Make sure to check if it will work in fuel related areas if thats where you are at. Dont assume anything, read the tube. I use high temp regardless.
Old Jan 9, 2010 | 10:31 AM
C4vettrn's Avatar
C4vettrn
Default Bolt threads
I have been using vasoline petroleum jelly on all nonsealing type bolts. It works good and you don't have to change your tourqe values any. And no I didn't think of this on my own I came across it in some high performance engine building book. Try it it works great and the price is right?
Old Jan 9, 2010 | 12:33 PM
engle1147's Avatar
engle1147
Old Jan 9, 2010 | 03:54 PM
RacerX70CC's Avatar
RacerX70CC
Next best thing to original formula GMS (sealer we used at the GM dealer)..
And liquid Teflon on the bolt threads - essential when using head studs!
Old Jan 9, 2010 | 04:24 PM
Weav's Vet's Avatar
Weav's Vet
I used The Right Stuff on my intake, Permatex Ultra Copper on my rear end plate and water pump, no leaks at all. I need to get some of the Liquid Teflon though.
Old Jan 9, 2010 | 09:14 PM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
St. Jude Donor '12
Tried the ARP stuff and it did NOT seal very well. Had to pull the heads again, clean it all up and do it again with the permatex.
To Favorite RTV
