From: Russellville, Kentucky 1967 Sting Ray & 2001 C5
I dunno. Some of what everyone has said in this thread doesn't seem to apply to my car. I put my OTC Genesis scanner on the car:
sensor clockwise = voltage down
sensor counterclockwise = voltage up
There is no power to the sensor with "key on - motor off."
Idle is directly affected but the TPS adjustment on my car. With engine running I adjusted voltage per the scanner to .18 vdc idle RPM 1000. That is with the sensor fully clockwise. Counterclockwise rotation increases voltage and RPM.
There are 3 wires to the TPS. 5V power, ground and signal to the ECM.
Way too low a voltage. Sounds like the ECM is adjusting based on other inputs like MAP or MAF depending on which one you have instead of TPS
I checked for vacuum leaks - none. What now?
Without knowing the type of ECM harness schematics and actual bin file in the ECM everything is just speculation based on how a stock system would react. If you do not have 12 volts at all the ECM pins that need it you will not get the 5v reference. Generally the only thing that changes from key on to running is the fuel pump relay closes and sends power to the pump. Ask for a real schematic and just follow the 12 volt stuff and most ECMs are documented on the net as to what pin has what. I am betting the idle speed change with tps voltage is one of two things. Either the bin file has the throttle follower to follow the voltage and open the IAC more with small changes in voltage or at an extreme limit the TPS is bottomed and more rotation opes the throttle blades. Without schematics and a bin file you and everyone else is just guessing including me..
I'm not familiar with their product, but I would think that there would be a minimum idle screw. If so, back off the screw until the blades are pretty much closed, then set the TPS and see what RPM you get. If it's still high, repeat the process.
Where does your scanner hook up ? Do you have an ALDL port ? Can you close the IAC, by jumping 2 terminals ?
What is the target idle rpm in the bin ? Does your scanner show this ?
Another way to go about it to set idle using IAC counts. With scanner plugged in, motor at operating temp, tps plugged in (as is), and at idle, what is the current IAC counts ?
If the motor is relatively modded (cam etc.) I would be looking for around 40 cts. (w/ idle inteded to be around 850 ish rpm), stock 10-30 cts. (650-750 rpm). Changing the min. air screw will change cts. and idle rpm. It would be nice to know the target idle rpm in the bin as well as the scan reading.
Maybe, but it appears as though his system doesn't not need the reference v. signal to start the car. My thinking is that perhaps the TPS is not currently wired to a true switched power source. In any event at idle, at operating temp., 1.8v. would be a high signal, and could indicate the TB blade is opened to far.
sorry bout that..yes typo on my part, and yes .18 is too low.
I still think it would be beneficial to know the IAC cts., check or re-do wiring from the ecm for a reference signal and go from there.
