tps measurement
Old Dec 28, 2009 | 06:10 PM
DBo's Avatar
DBo
Default tps measurement
Can somebody give me the procedure on testing and adjusting the voltage of the tps on an 84 Crossfire? Thanks, Dave
Old Dec 29, 2009 | 09:29 AM
DBo's Avatar
DBo
Can anyone help me? As the final step in balancing the throttle bodies, I would like to check the voltage of the throttle position sensor. But all that I get from searching is pretty vague.
Old Dec 29, 2009 | 06:58 PM
JAKE's Avatar
JAKE
Not up on the 84, but am in the 86. Are they similar? If so I can help.
Jake
West Point ROCKS! Nation's TOP COLLEGE per Forbes Magazine!! Graduation Day Parade 20 May 2010!!!
Old Dec 29, 2009 | 07:04 PM
WW7's Avatar
WW7
Since the 84 is pretty unique with some of its parts and procedures it wouldn't be a bad idea to get a Factory Service Manual. These can be had fairly cheap from guys on this forum and possible ebay.Trust me, it would be a big help...WW
Old Dec 29, 2009 | 07:10 PM
JAKE's Avatar
JAKE
Three TPS wires; use the TOP and Center to connect the digital volt meter. Ignition ON, engine OFF. Take a reading. You need to use a DIGITAL volt meter, not analog.
It should read .54 volts +/- .075 v. If not, loosen two screws and turn TPS until you get the reading you want. Tighten screws, then verify that voltage didn't change. Done.
Jake
Old Dec 30, 2009 | 12:31 PM
DBo's Avatar
DBo
Jake,
Thanks! Dave
To tps measurement
