Strange Hesitation please help!!!!
Old Jan 5, 2010 | 07:38 AM
pcolt94's Avatar
pcolt94
Originally Posted by 94vettelover2
If you tore everything down to get to opti just replace it-no sense in just replacing the cap & rotor when your there.The opti is also your cam sensor as well.Also there should be NO arcing out of wires & if new wires are arcing they are defective/bad.Fill an empty spray bottle full of water & mist spark plug wires checking for "leaking" spark.Get quality wires not cheapes.First fix arcing wire problem before doing anything else
This is definitely a good starting place with the routine stuff. I would as said check the fuel pressure and FRP as well. I would also take a look at the TPS (throttle position sensor) and check the voltage off the center wiper for a smooth transition from 0 to 5 volts.
After all that then I would probably zero in on the opti as you do have some classic signs of it being defective.
I would put the injectors last on my list as those year cars have injectors that hold up very well unlike the earlier vetts of the 80s.
Old Jan 17, 2010 | 04:39 PM
darkstallion_69's Avatar
darkstallion_69
I just wanted to comment that here in florida we had a cold front for about a week. within that week ive head minimum hesitation as the car has stayed at about 175 degrees. Even though i can feel something is not right the hard hesitation is gone. Our cold front is gone now and the car performs the same until about 200 degrees it then progressively hesitates worse and worse as the temps rise. It hesitates on light, moderate and wot. As I stated before im gathering up parts to change for next weekend. Ive bought new bosch spark plug wires, bosch platinum plus spark plugs, purolator fuel filter, BVD ignition coil an i ordered a new gm water pump and a new msd opti. Anything else you guys want to suggest? Ill be running a diagnostic this week to see if I have any codes. The car has 150,000 miles and ive only had it a year and its unknown to me what has been replaced. So all this to me is routine I think stuff that should be replaced anyway. By the way my carruns rich what could be the reasons for that? my car is stock except for the exhaust and an open airlid.
Old Jan 17, 2010 | 06:02 PM
darkstallion_69
ttt
Old Jan 17, 2010 | 07:25 PM
coorslight's Avatar
coorslight
My 94 with 40,000 does the same thing, Do you think i would need a new opti?
Old Jan 17, 2010 | 07:55 PM
darkstallion_69
im not sure thats why ive been posting here. Most cases its the opti. Ijust so happened to have wet mine and it started hesitating a week later. But like mosta people have posted it could be many different things thats why im changing more than just the opti.
Old Jan 18, 2010 | 11:19 AM
L71Maynard's Avatar
L71Maynard
I've got a similar hesitation problem that developed a few weeks ago. I have tested all the components listes in this thread, plugs, wires, ICM, coil, TPS, etc and believe my problem is with the opti. I'm tearing down the car to do the opti and waterpump this week and will let you know how it turns out.
Dave
Old Jan 18, 2010 | 11:28 AM
MK 82's Avatar
MK 82
Tell us more about this "cam sensor."
Old Jan 19, 2010 | 10:45 AM
darkstallion_69
Ttt
Old Jan 19, 2010 | 10:46 AM
darkstallion_69
Dave
yes please let me know how it goes.
thanks
Old Jan 20, 2010 | 12:24 PM
94vettelover2's Avatar
94vettelover2
Your not serious?
Old Feb 23, 2010 | 07:18 PM
MK 82's Avatar
MK 82
Your not serious?
As a heart attack. Just exactly what does this "sensor" sense?
What happened to the original post?
Old Feb 23, 2010 | 07:42 PM
Jonnymac's Avatar
Jonnymac
St. Jude Donor '08
I would look in to the ICM.
http://forums.corvetteforum.com/c4-t...1-shudder.html
Old Feb 24, 2010 | 03:34 AM
  #33
94vettelover2
This sensor & distributor assembly has a optical sensor that measures the position of cam/crank.It sends signal to pcm that lets it know precise location of cam/crank.From 1992 to 1995 the opti was the cam & crank sensor as well as the distributor.The 1996(obd 2) vette had a cam(opti) & a separate crank sensor that mounted on side of timing coverGlad to help
Old Mar 17, 2010 | 11:39 PM
  #34
1973Jasonr's Avatar
1973Jasonr
Did you ever get your car to work right? Do you happen to know what it was? I was just curious, because mine is doing the exact same thing. I have a 94 with 15,000 miles.
Old Mar 18, 2010 | 12:11 PM
  #35
darkstallion_69
Well i bought the new opti from a forum member about a week ago. Im going to be doing the job soon ill let you know. Im sure mine got wet because it started doing it after I cleaned the engine. My car hesitates the most at low rpms at high load and when the car is over 200 degrees.
