I bought a batter tender at Wal Mart before last winter and it worked great, keeping the battery charged for when I would take it out every few weeks. I didn't plug it in to the car at all after the winter but now I had it plugged in from a few weeks ago and the little light was green when I plugged it into the lighter so I thought the battery was all charged up and it would keep it that way. But now, it is really dead.
I thought it might have not made a good connection but all my testing showed that it did. So I thought the charge somehow burned out something over the 8 months of not being plugged in.
But when I opened the hood with it still plugged in, the little light went amber - due the inner hood light draw.
When you say "really dead", do you mean a volt meter is showing less than 12 volts, or the engine fails to crank over ?
Are the battery connections clean and tight ?
Does the car do anything? Headlights, starter?
If not, remove and clean your battery cables as a starting point.
Measure the battery voltage before connecting the tender. Then plug in the tender, if it is good, your voltmeter will show an increase in voltage and it won't be very much. Dead batteries read 12.0 volts or lower. Don't expect the tender to charge up a totally dead battery, use a higher current (like 6 amps or higher) battery charger. When the battery is charged up, try your tender again.
Thanks for the responses but the issue is the battery tender, not the battery. Starter is a bit touchy lately so it needed an extra zap by turning the key a couple times to kick it off. But it doesn't turn over now and only minimal lights.
Question is why doesn't tender show any drain (amber light)? Lighter socket works cuz when I plug in cell phone charger, that works.
The orange light comes on only with a certain amount of drain current and you don't know what that value is nor do you know what the drain is on your battery. Get a VOM (voltmeter, ohmeter, milliameter) and perform the test I already posted. You don't have to spend a lot of money for a decent meter, Harbor Freight sells a digital VOM for $8. With it you can measure the state of charge on your battery and its drain current and the current your tender is supplying the battery. If your tender supplies less current than the drain current, then it will never keep the battery charged up!
GM says the drain current should not exceed 50 milliamps. 12.0 volts and below, battery discharged, 12.9 volts and above, fully charged and linear in between.
This may or may not be relevant to your issue, but is your 'battery tender' the actual trademark Battery Tender product or are you referring to any battery maintenance product as a battery tender?
I have only used the trademark Battery Tenders on my cars (hard wired), and have never had a problem. I sleep above one or two while in operation. I will never sleep above an $8 unit from Harbor Freight or Walmart. I have had a car burn up in my driveway, and I am not going to let it happen in my garage.
From: Southside of Western Norte Americano State of Confusion, ColoFornia
St. Jude '13
I believe the 8 bucks was a reference to the cheap digital multimeter needed to determine if the battery is flat or or not. not the original float charging maintenance device.
while it is convenient to wire them to the cigarette lighter plug.. this is forcing the charge to go back through the battery terminal connections, Which with a dirty connection will net you exactly these results. I prefer wiring the charge direct or clipping to the batt terminals themselves. (after all the battery is what you are charging)
TIA
Nope, its the battery, I have seven C4's with tenders on them, two motorcycles, and one four wheeler, and one riding lawn mower. When the battery is toast, the tender will almost ALWAYS show green, its the little diode in it. Your battery needs replacing. Your tender is ok.
