Brake problem 1987 C4
Old Jan 5, 2010 | 11:35 AM
railer75's Avatar
railer75
Default Brake problem 1987 C4
I have been having a brake problem with my 87 C4-the front brakes hang up and don't completely release causing a lot of heat build up in the front wheels and excessive pad wear! I have pretty much replaced everything- rotors, pads ,master cyl. They will release if I reduce the hydraulic preesure by opening the bleeder or the connection at the master cyl or the abs module. I decided that the abs module was the problem-sticky solenoid and abought a used unit for 87 on Ebay-it looks the same and seems to have the same model # but the one in my car has an extra wiring harness - can any one offer any info on this extra harness and can I install the replcement without it? I would appreciate any help! Thanks
Old Jan 5, 2010 | 11:41 AM
pcolt94's Avatar
pcolt94
Possibility the front flex lines are bad and have a restriction in them from heat and time.
There is also a possibility the actuator rod out of the brake booster is out of adjustment and needs to be set correctly. Easy way to check is to loosten the master nuts and slide back the master an inch or so back and see if the fronts release.
Old Jan 5, 2010 | 11:55 AM
railer75's Avatar
railer75
Bothe front brake lines were replaced- rears work fine so I don't think it's the actuator rod or booster. Thanks
Old Jan 5, 2010 | 12:25 PM
c4cruiser's Avatar
c4cruiser
It's also possible that you may have an obstruction in the line that goes from the master to the ABS unit and back to the brass tee fitting for the front brakes. When was the last time you did a fluid flush? Brake fluid that sits in the reservoir for years can have solids build up and they eventually work their way into the lines. It's also possible to have the line itself have some internal rust or corrosion that would cause pressure to not release.
The ABS pump only works when the VSS signals tell it to. It also runs briefly when the car is started and moves through 3-4 MPH. You should hear a buzzing sound from the pump doing a self-test.
Old Jan 5, 2010 | 12:37 PM
railer75's Avatar
railer75
The system was recently drained, flushed and the brake fluid replaced- the front brake hoses were also replaced.
Old Jan 5, 2010 | 12:52 PM
DoctorG17's Avatar
DoctorG17
Default ss brakeline kit
I kave a 1990 corvette. I Want to put ss brake lines on it, The ones I have are G-stop kit 12204, This kit has round ends to bolt to front calipers, my stock ones are shaped like a triangle to lock into place. can I use the round ones, or will they turn on me. Thanks John.
Old Jan 5, 2010 | 01:33 PM
pcolt94's Avatar
pcolt94
Not meaning to insult your ability at all. But with out actually checking the actuator rod you are bypassing what can be a simple solution. It does not take long to jack up one wheel and loosen the nuts on the master to make 100% sure. If the master cylinder piston does not return to its full return position, the calipers might not release completely.
If you have actually checked it in this way, then I guess your OK.
Old Jan 6, 2010 | 11:55 AM
railer75's Avatar
railer75
Default C4 Brakes
I have checked the actuator rod and it is not the problem-We are focussing on the abs-I need info on the 2 differnt abs units -whether they are interchangeable. Thanks
Old Jan 6, 2010 | 12:09 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Check the shuttle valve in the MC. Make sure it is centered
Old Jan 6, 2010 | 01:18 PM
pcolt94's Avatar
pcolt94
I hear that. Back a while ago 2 years or so we had a number of your vintage cars with similar problems and it turned out to be the ABS unit. However I only remember those people usually had problems with only one wheel.
Sounds like your heading in the right direction.
Old Jan 6, 2010 | 02:31 PM
94vettelover2's Avatar
94vettelover2
The calipers could also be the problem or maybe you installed incorrect pads or rotors.Also there could be a restriction like previously said not allowing proper return of brake fluid.If I had to guess I would say the calipers are bad or you installed incorrect parts that did fit(parts could be boxed wrong or for wrong application).If the ABS unit you got don't look correct it probley isn't-no wiring cutting should be needed unless dealership says so(updated unit/harness.Let us know what problem is
Old Jan 6, 2010 | 03:01 PM
railer75's Avatar
railer75
Default C4 Brakes
The rotors and pads were installed by the Chevy dealer that I bought it from-so I assume they are correct- The calipers have been checked- Thanks
Old Jan 6, 2010 | 03:29 PM
94vettelover2
Did you have this problem before or after they replaced the brakes?Never assume,I've fixed dealership f-ups many times.
Old Jan 6, 2010 | 04:13 PM
railer75's Avatar
railer75
Default C4 Brakes
The work was done before I bought the car-I didn't notice the problem for a while- but I occasionally noticed a smell like something was hot-and checked the wheels- At this time I had put about 500 mi on the car so I can't say whether or not it was like that when I bought it.
Old Jan 6, 2010 | 11:46 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
If you are releasing the pressure at the master cylinder by opening the lines AT THE MASTER CYLINDER, you have a bad rebuilt master cylinder, or the booster pin is misadjusted
To Brake problem 1987 C4
