Error Message
Old Jan 12, 2010 | 07:53 PM
soldierboy609's Avatar
soldierboy609
Default Error Message
What does "SYS" mean, it flashed several times while runing the car up to operating temp during the cold spell??
Old Jan 16, 2010 | 08:37 AM
jlr4115's Avatar
jlr4115
Default sys
You might want to check for any fault codes first. Also, if and when the light comes back on, flip coolant/voltage dash switch to voltage and see if there is any fluxuation in voltage while running.
Old Jan 16, 2010 | 09:08 AM
STL94LT1's Avatar
STL94LT1
Your battery charge is low.
To Error Message
