drivers side headlight stuck open
Old Jan 14, 2010 | 11:49 AM
lbrehm02's Avatar
lbrehm02
Default drivers side headlight stuck open
I have a 89 convert and the drivers side headlight is stuck open. Checked the power at motor plug and recieving no electric current. Is there a fuse for this and if there is how about a location.
Old Jan 14, 2010 | 11:52 AM
runner140*'s Avatar
runner140*
For now, do the manual thing and turn the manual **** until it is fully closed.
Old Jan 14, 2010 | 12:09 PM
lbrehm02's Avatar
lbrehm02
Default New to the vette world
forgive new to the vette world here but mechanically inclined. How would you manually close?
Old Jan 14, 2010 | 12:12 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
There's a black, platic **** on top of the headlight motor. It's for backup operation of the headlights. Check your owner's manual for details.
Old Jan 14, 2010 | 12:20 PM
engle1147's Avatar
engle1147
When triggered (turned on/off) initially if one head light works and the other doesn't even try to work it is possible that you've got a bad head lamp actuator motor, open or shorted wire/wires in the actuator circuit or a bad head light control module.
Old Jan 14, 2010 | 12:26 PM
lbrehm02's Avatar
lbrehm02
I checked the wiring harness and no current going to the headlight motor
Old Jan 14, 2010 | 12:37 PM
engle1147's Avatar
engle1147
If you checked it for voltage at the connection plug "at" the headlight motor and had nothing follow the wiring back to the headlight control module (5"x 1" black plastic module bolted to the front side of the left front wheel well shroud - near the vacuum ball) to insure there are no issues with the wiring.....would also be a good idea to remove the electrical connection for both the module and headlight motor and check (continuity) the harness wires that feed the non working headlight motor...you'll need a jumper wire to complete the loop. Both the module and headlamp motor should be unplugged for the resistance test. If everything checks out you'll need a new or "good" module (used ~$50 on flEaBAY).
Old Jan 14, 2010 | 01:01 PM
lbrehm02's Avatar
lbrehm02
Thanks engle1147 I will try this.
To drivers side headlight stuck open
