Engine rebuild advice
The issue with Eagle is machining consistency. All the journals on my crank needed to be turned. Really ticked me off but it all worked out in the end.
I used SCAT lightweight H-beam rods. In my 383 thread there are some side-by-side pics of my old SCAT H-beam rods and the new ones. The difference in weight is significant and it's obvious in the pictures.
Pistons were the challenge for me. I used SRP which were fairly light. The battle was finding an inverted dome that would give me the CR I wanted. As a result I ended up having to compromise a little since custom pistons weren't in my budget.
I have a new hot cam and ported 113 heads, they only flow 235 at .500 though.
Going to the 383 would cost me losing a track event, since they cost about the same. I think I'd rather attend the event but I want to be happy with the engine for a long time.
Interesting about the dyno gain with the pistons. I had heard that before but not see a HP number.
Power band, I'd like the engine to live a good long life plus I have a SR and wasn't planning different rear gears.
It would hard to find bearings to fit a tapered journal seeing bearings are not taper
We tent to stay with the Callies Compstar line and there pricing seems to be really good. and Scat would be my second choice.
And over the years building engines I have had to many calls about broken or worn cast cranks.
If you ever had to the chance to drill a cast crank or 4340 carnk when balancing, The cast crank is like drilling butter compared to a good forged crank.
We stay away from cast cranks and Hyper pistons and so far I don't see the problems my competition is having and we do a lot of balancing for other shops and local guys building engines os we see whats going on out there.
Don't get me wrong not every Eagle crank is junk but I don't have time to keep sending them back when they don't pass my inspection.
Here is a link to look over.
http://www.yellowbullet.com/forum/sh...d.php?t=114102
One peice seal cranks are available. The light weight cranks are cheaper then some of the Scat light weight cranks.
Hell I can buy 4340 cranks for 325.00 but there not very good quality and H-beams for 175.00 by I will pass on the stuff.
That's the hardest part about building an engine...When are the parts that are selected "good enough" for what the user intends? You see some guys with tens of thousands in engines that do nothing but putter around the street and then you get some of the Mustang guys that go thru the proverbial $200 engines like candy.
What I'd like to do is go down to the store, get some beer, drink that all up, then decide what CID I'd really like.
Anyone have a decent 383 cam they would trade for a hot cam?
I spent the last 6 months talking to lots of people looking for the "right" answer so some of the questions you posed here, like: hypers vs forged, 5.7" v 6" rods, longevity, Scat vs Eagle, forged cranks vs cast, engine life at higher rpms, etc.... I talked to multiple forum members and multiple (local) builders. The conclusions I found are these....
Inverted dome pistons are better for various reasons. Flame travel/consolidation create the best burn and efficiency. You can get the highest compression and/or best efficiency (esp w 58cc heads) using that design. More info on that here: http://www.kb-silvolite.com/article....n=read&A_id=36
Everyone (except the builder I chose) agreed that forged pistons are a better choice than hypers. Kinda ironic LOL! Had I not found a great deal on eBay, I probably would have used the KB9926 inverted dome pistons for 5.7" rods @ $275. Because I noted inverted domes can increase heat (mentioned in link above) while 5.7" rods help to reverse that (because they're slightly faster pulling away from TDC), this sounded like a good combo IMO. Also, these have the higher Silicon 4032 Alloy and run at slightly tighter tolerance than standard 2618 forged. SRPs Pro series were may favorite choice but higher priced. Lighter than heck though.
Scat cranks are harder than Eagle as testified by builders who'd drilled into both. Also, no builder was skeptical that a cast crank wasn't strong enough for the level of build you (we) are building. And, they are 1lb lighter in the 9000 Series at 51lbs.
A 383 will run as long/well as a 350 if built/balanced right. No need to worry about going to a 383.
Without looking at your gears (ratio), converting to a 383 will add torque EVERYWHERE. Off-idle all the way to redline. It will go alone way to satisfying your need for higher torque. (Obviously, a 383 and higher gears would be fun too!)
The hotcam could be improved upon -- going to a 383,,,but you also have the issue of 235cfm stock heads to consider. More headflow or more duration could feed it more air. Depending on your desire and/or long-term plans (if any) to upgrade your cam and/or heads could play a part in deciding the best CID for you.
That's using a flat-top. Otherwise, if Kubs calculations are correct, then an dish is going to lower compression enough anyway.
BTW: I'm going to double-check the calculations later today. It's kinda hard for me to believe a flat-top can get 10.7:1 with a 58cc head. Figuring out the approx dish size will help to figure out what inverted dome pistons are even in the running. With a 383 and 56cc head, I was looking at 10.7:1 with a 16cc dish. (.040 quench).
Knowing the desired CID would help too!
