195 heads
Old Jan 30, 2010 | 09:30 PM
1996man's Avatar
1996man
Default 195 heads
im curious as to the most N/A HP anyone has made with a set of 195 heads. i know the LT4 heads are 195 castings and people have made well over 500 crank HP with those heads when they are completely ported but by that point they usually end up well over 210cc by the time they flow close to 300cfm intake. the highest i have seen is the motor that TPIS built with an off the shelf cam and a set of competition AFR 195 eliminators which flow 301 intake out of the box. they put it in a NA 396 lt1 with only a 58mm TB, 30lb injectors and 1 3/4" primary headers with only minimal intake porting. the peak was reached at about 6200rpms or so and was 552 crank HP. anyone make better numbers with 195 heads? perhaps with a more wildly ported intake or something? any input is welcome.
Old Jan 30, 2010 | 10:35 PM
cv67's Avatar
cv67
St. Jude Donor '05
You can make more than 550 but it will take an agressive solid roller, some compression and plenty of rpm. QUestion is would you want to street drive it when youre done....if you can even get the power to the ground.
Old Jan 31, 2010 | 09:52 PM
1996man's Avatar
1996man
While I agree with you for the most part, i was simply curious what the power limits are of heads this size. regardless of it is considered "streetable" or not.
Old Jan 31, 2010 | 09:57 PM
cv67's Avatar
cv67
St. Jude Donor '05
Limits are going to vary by mfr.
Old Feb 1, 2010 | 08:40 PM
96 lt-4's Avatar
96 lt-4
I will guess 600hp would be near the upper limits.It would take better than stock internals,lots of compression,cam duration,and have a narrower power band(like 4000-7000rpm)most likely.
Just guesses on my part so fire away if you disagree.
Old Feb 1, 2010 | 09:47 PM
1996man's Avatar
1996man
i have seen several builds between 500-550crank HP that were using a cam that didnt rev even close to 7K. but i agree with you. Although it would definatly hurt bottom end torque, I think that if you had a 383 or possibly even a 396 that would rev to 7K along with around 12:1 compression along with a monoblade and 1 7/8" headers, I think you would see 600 crank HP no problem.
Old Feb 1, 2010 | 09:52 PM
cv67's Avatar
cv67
St. Jude Donor '05
600 hp takes a lot to get there with a 350 and reliability will be a concern. Build bigger if you can, as the powerband goes up to acheive HP you will kill low speed torque and drivability. With more CI it makes a 525-550chp build much more tractable to drive and tune.
Old Feb 2, 2010 | 12:45 AM
Curveit's Avatar
Curveit
I think with the Comp AFR 195 Heads (300 CFM), you could probably make close to 640-50 HP, with enough motor and parts.
Old Feb 2, 2010 | 06:44 AM
88BlackZ-51's Avatar
88BlackZ-51
First off what kind of cubes are we talking? Big difference between a 355 LTx, and a stroked 409 LTx.
The most of have personally seen is in the area of 495rwhp in an LTx, and those LT4 heads were ported to chit, and it reved to 7000 rpm's if not a tad more. This was a 398 if memory serves me.
Here is a 409 LTx that I stumbled on:
http://www.strokerengine.com/DynoTPI.html
Old Feb 2, 2010 | 07:41 AM
1996man's Avatar
1996man
ive seen a lot of LTx engine builds lately that used extremely ported LT4 heads to get some very impressive numbers. but like i said before. The LT4 heads start out as a 195 casting but by the time they port them to flow enough to make those impressive numbers, they end up having a size of over 210cc. i cant help but think this would hurt bottom end torque. looks like the only 195 head that flow enough to make big power without getting any bigger than 200cc is the competition AFR eliminator series. from what i have seen, those AFR heads should be able to make just as much power as a ported to sh*t LT4 head and still maintain even better low end power and torque making driving it on the street that much more of a reality since you wouldnt have to rev it to 4k just to leave every stoplight. these are just my impressions and im trying to learn about heads as it is so please feel free to correct me if i am wrong.
Old Feb 2, 2010 | 07:49 AM
Kubs's Avatar
Kubs
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
Are the HP and TQ numbers in that link at the crank I assume?
Old Feb 2, 2010 | 08:11 AM
bjankuski's Avatar
bjankuski
To figure out what HP the heads can support there is a rough formula that can be used. This formula assumes a correctly built engine that can utilize the head flow and in maximizing the combination. In street trim the formula is (Intake port flow x .256 x number of cylinders) in the case of the AFR head 300 x .256 x 8 = 614 HP. This is a rough number you can make more than this but then engine will be more race orientated.
A side note 210cc or 220CC heads on a large cubic inch SBC do not feel lazy at low RPM. My 406 with 218cc heads can break the tires loose at low rpm rolling into the gas in second gear.
Old Feb 2, 2010 | 10:17 AM
cv67's Avatar
cv67
St. Jude Donor '05
Id bet the farm most those ported to death LT4 heads are more like 220-240cc runners. Why bother exhaust cant keep up anyway
To 195 heads
