engine
Old Feb 2, 2010 | 11:23 PM
Jackwmonk's Avatar
Jackwmonk
7th Gear
Default engine
i just traded for this car it ran fine for 2 days and then started missing and after running for 10-15 minutes it blows white smoke out i side and the gas smell blows you out of the car any suggestions that why i was thinking of thge engine swap
Old Feb 3, 2010 | 11:54 PM
1stL98's Avatar
1stL98
what year is the corvette,white smoke usually means coolant in the combustion chamber,i.e. head gaskets or cracked heads.did it overheat.we need more info to guide u thru a proper diagnosis.
