Bolt size/ u-joint strap?
Old Feb 3, 2010 | 02:07 PM
Elrick's Avatar
Elrick
Default Bolt size/ u-joint strap?
does anyone Know what the bolt size is for the half straps on the u-joints for the rear axle. The bolt hole is cross threaded and I need to try and re tap it. Just need to know what size tap to use so I don't screw it up anymore.Thanks
Old Feb 3, 2010 | 02:21 PM
engle1147's Avatar
engle1147
Those u joint saddle straps may also be damaged if the hardware installation is any kind of indicator.
You may end up going a different direction with something like this (check your application for fitment/sizing):http://www.summitracing.com/parts/PC...ke%7cCHEVROLET
Old Feb 3, 2010 | 03:02 PM
aminnich's Avatar
aminnich
Take a good bolt to Home Depot and find the nut that fits correctly. Then you will know what you need. Pretty sure they are metric, that is about as far as I can help.
Old Feb 3, 2010 | 04:59 PM
Elrick's Avatar
Elrick
Thanks, good tip
Old Feb 3, 2010 | 05:18 PM
pmihaltian's Avatar
pmihaltian
Slingshot
They are 8mm. Take a look at the u-joint replacement write-up I just sent to you.
Old Feb 3, 2010 | 05:19 PM
86PACER's Avatar
86PACER
Or if you have one, measure the threaded diameter of the bolt with a dial caliper, then find the thread pitch with a pitch guage. That's the way I do it.
Old Feb 3, 2010 | 08:05 PM
Elrick's Avatar
Elrick
Thanks for the advice. I did not receive the write up though, just a thumbnail of the bolts.
Old Feb 4, 2010 | 01:13 PM
pmihaltian's Avatar
pmihaltian
Slingshot
Its attached to your post about your rear wheel bearing problems....
To Bolt size/ u-joint strap?
