1989 wont idel when cold
The rest I don't know.
Do you have a FSM? If not that's the first thing you need to purchase.
I don't know what year they quit putting the cold start injector in them for sure.
Mine is a 90 and it turned out to be the IAC (Idle Air Control) I'll look for my thread on it and post it up.
http://forums.corvetteforum.com/c4-t...ue-solved.html
It's at post 8
http://forums.corvetteforum.com/c4-t...-symptoms.html
Do this. It's what I did to figure out the IAC.
Take out the IAC. Clean it throughly with carb cleaner and an old tooth brush. Or you can use your good toothbrush if you wish
Then clean out the cavity where the IAC goes by spraying the cleaner on a rag and wiping out the cavity good. The wipe out all carbon, you can get to, in the throttle body.
Also take note when you take it out and look to see if the IAC is extended or it is contracted. In my case it was fully extended and and stuck thus not allowing any air in.
Put it back in and see if it idles. When I did this it didn't idle 100% but it did idle so I knew this was my problem.
this is a no cost thing you can do unless you have the equipment to test the IAC. As a thought also. If your car will start with throttle it can't be the cold injector, if you even have one which I don't think you do.
Also keep in mind if it is the IAC something has probably caused it to get gummed up. More than likely a rich fuel condition.
Almost forgot. When you reinstall the IAC you will need to reset it. You do this by starting the car and hold a little idle for 5 seconds. Then you turn off the car while still holding the throttle. Wait ten seconds and then restart. That will reset your IAC.
The pellet in key, is read by the VATS module. If it's happy, it will allow cranking and injection. You cannot remove the VATS module. You can trick the VATS module, by unplugging the 2 wires going to ignition switch and putting resistors of the correct resistance, between those 2 wires.
This site will help with that, if it is VATS that is causing the problem.
http://www.joestradingpost.com/vats/
Cleaning the pellet on key, may help.
As stated, your idle problem could be linked to the IAC.
Test it to see if it's working.
http://members.shaw.ca/agent86/IAC%20Diagnosis.pdf
You may also want to try and set the minimum idle and TPS.
http://www.lbfun.com/warehouse/tech_...ch%20Paper.pdf
http://www.youtube.com/watch?v=_g8Pd...layer_embedded
Here is another one, not a professional video but it gets the point across..
http://www.youtube.com/watch?v=ValTYJUfPA8
In 1989, they programmed out the start injector, and programmed the injectors to provide cold engine fuel until the temp sensor tells the ECM that it is in closed loop mode, and can fully regulate with all the sensors.
Your symptoms sound like somebody put in a 86-88 chip, and it is asking for a cold start injector that's not there.
