Shift Cable
Old Feb 6, 2010 | 01:51 PM
floridamale's Avatar
floridamale
Default Shift Cable
87 700r4 Auto
Replacing this cable is a royal PITA
Coming home last night I hit something in road and trans became stuck in low.
This morning I checked under the car seems like the plastic around the cable has come loose from the housing it mounts into so I have no shift control.
Found a new cable but will have to order it.
Any tips on doing the replacement? What should I watch out for?
I have already removed the old one. Found the best way was to remove heater control head and console top so I could disconnect from shifter then slide it back and out of it’s bracket. Looks kind of straight forward on install just want to be sure I’m not missing anything.
Old Feb 6, 2010 | 03:58 PM
Calderone's Avatar
Calderone
http://forums.corvetteforum.com/c4-t...-is-stuck.html
http://forums.corvetteforum.com/c4-t...placement.html
Old Feb 6, 2010 | 04:02 PM
Calderone's Avatar
Calderone
Originally Posted by floridamale
87 700r4 Auto
You are on the right track,the hardest for me was a tiny C-Lock that went on the side bracket...let me know !!!
Old Feb 6, 2010 | 04:30 PM
Weav's Vet's Avatar
Weav's Vet
Actually if you had waited to take the cable out it may have been better. B&M makes one without the boot you can pull through the grommet in the floor. You connect it to the old cable and pull it through.
To Shift Cable
