How much compression is too much, for 93 octane.
For what it's worth, I just ran a couple of sims of engine setups from the late 90s; a Cup engine and a Pro Stock engine. The Cup engine had a DCR mid 7s and the Pro Stock mid 6s.
I don't know if any of that helps, but there it is anyway.
Jake
I don't know anything about Patterson or the origin of the sticker though.
I just built and maintained the engine; then popped the chute at the top end, LOL.
Jake
I should have qualified my suggestion of .050 squish by saying that's the most builders (who pay attention to quench) would go. Some say stay between .035 and .045,,,while others say .040" to .050" works well. (I was unable to qualify that further -- based on compression or any other criteria.)
I you look at the kit Red-85 specified, it's pretty clear what parts are being used. Scat9000 crank, 4340 rods, and 5cc flat top forged pistons. He specified the cam, the heads, and the kit is for a 2pc RMS motor -- which means an internally balanced kit can be used. And, he specified the heads too.
The best advice I got, Red was to stay conservative. For someone wanting to build a motor once, try to avoid all problems/possibilities of a redo, choose parts at least 1 step below limits, pick good parts, and work with people you trust.
For the compression thing, you should know/understand that 1pt compression only gets you 10hp improvement (on avg). By contrast, going to a 383 gets at least 3x that amount. Since you're also planning a TPI, it seems apparent that TQ is more important to you than HP -- though what your building should pull hard enough for anything short of racing.
Finally, in the spirit of staying conservative (like Bjanuski suggests), I did too. My suggestion was a bigger dish with the 64cc heads. They're better pistons and the compression would be down where it's hard for anyone to challenge it's viability. For a 1-time build, why not be safe? Do you need every last ounce of power?
He said that "Without the science to back up claims, you're just making 'stuff' up." Once you think about it . . . .
Jake
Jake
Personally, I think it's reckless to randomly say 11.3:1 is doable for everyone.
Edit: To be clear...I mentioned 11:1 as a doable compression ratio earlier in this thread. That was before cams specs were provided -- leading me to a better understanding of the high dynamic compression generated for this person. With that info up front, I would never suggest that 11:1 is doable -- esp on a mail order tune. Doesn't mean it can't be done either,,,but in this case 9.25+DCR is flirting with disaster. Even the people I know who are running 11:1 or higher, don't have DCR that high.
Your post got my attention, I grabbed my paperwork from the machine shop for a review and I was wrong. My compression is 11.1:1
(Phone numbers are to thank or bitch at them depending on whether they're right or wrong.)
Edit: Seriously Jake? That's all you have to say? Nothing worthwhile? At least I gathered as much feedback/info from (LOTS of) various sites, talked to a dozen engine builders and formed an opinion of what's the right thing to do ESPECIALLY for someone not building on a past design/application. Piping in about the need for science w/o providing your own perspective/reasoning is like standing there with your finger in your nose. (So much for your new ploy to challenge for scientific foundation.)
There is some science posted/listed in the sources from which I draw too, but I'm not going to go back and reference every one. As it is, I think I reference more than most people anyway. For example, go back and follow the link I provided back in post #20. Read all of the connected (linked) material in THAT post & the ones linked from that. Then talk to a dozen builders (including a couple on a national scale), then come back and try to recommend to a person exactly what's safe and what's not. You darn well better believe that those providing more conservative advice while having some point of reference/measure are better contributors than people saying "My LSx, LTx, is setup to get 11:1 compression -- so that means every other car will be fine with that combo".
I don't know if Red is going to build this motor himself or have help from a builder. If the later, I think that's who should be providing most of the advice/recommendation. OTOH, lots of builders get crap thrown at them and get told to assemble it. So, often, they just build. Two of the best contributors to this forum told me to go looking for a local with a good rep around town -- and have him advise the build. I think that's great advice -- especially if the builder will stand behind the combo being built.
Otherwise, if you take advice from forum's like this (without any wiggle room if you're wrong), then it'll probably end up differently that you hoped. OTOH, if you check/double-check with multiple sources until you to get to a reasonable truth you can believe in, you'll probably be O.K. So, I that's my recommendation.
Footnote: For what it's worth, my sources include Vizzard, GrumpyVette (and the sources he quotes), TPIS, CNC-Motorsports, the online performance mags, Bullet Cams (and Comp), The Engine Store, two of the most experience forum members (who don't want to be named), Alvin (PCM4Less), another tuner, four local builders, and the one I'm using.
Only 1 out of this list feel it's safe to go above 10.5SCR and 8.5DCR -- if you want to be guaranteed "detonation-free". All of them said tune would be critical as you get close to that "boundary". Most said staying 1/2 pt under that boundary was the safe thing for a person not needing every last 1/10th in the 1/4 mile. A couple said "DCR, What's DCR? I don't pay attention to no stinkin' DCR!". All of them said it's complicated with lots of variables like: quench, static compression, water temp, gasoline quality, electronic timing, dynamic compression, piston hotspots (or lack thereof), head material, etc..., etc....
The ones who said they recommend 10:1 with a DCR of 8:1 were the ones who'd built the most motors. They're the ones who have to stand behind what they build. And, they are the ones who I personally feel are the safest to follow. Again, that doesn't mean you can't get away with a lot more. But, you better be WELL prepared to understand tuning, go to a good tuner, and/or do the right things to make sure you don't damage you one-time build.
Other things to consider include (as mentioned above) gas quality. How is it near your home/work? Are you prepared if it starts to degrade in quality? Does that matter? How much timing are you willing to take out -- if you have problems? What things can you improve on -- if cooling isn't adequate? Will you have any loss of HP thru oil drag? There are more questions/issues that you can imagine -- unless you've been doing this for years of course.
BTW Red,,,,Don't let all of this scare you off. These are issue you'll have to address whether you do a 383 or 355. It's just part of the game.
What's your quench, what type of piston (shape), etc... etc....
And, the biggey,,,,will you pay for Red's engine IF YOU'RE WRONG?
..WW
And, the biggey,,,,will you pay for Red's engine IF YOU'RE WRONG?[/QUOTE]
I'm not pay for anything buddy. I posted my compression numbers and that we only have 91 in California. We have our choices, AC spark plugs were recommended by Jim and I chose AC spark plugs. If a plug blows up, Jim would have to pay?...please get real
like Neo said,
"The problem is choice"
Good reading here, I'm rebuilding mine to.
The reason DCR is so important is because it's a better measure of the compression. Without a cam, the valve's would never open/shut. So, it's the cam that controls how compression builds.
As the piston is coming up the bore, it won't start building compression until the valve closes. DCR is a better measure of when that door actually closes and compression starts to build. Take two builds for example, If both are 10:1 compression but build #1 closes the valve 20% up the bore while the other doesn't close until 30% up, compression would be 8:1 vs 7:1. Obviously, that's a huge difference.
The difference in adv vs .050" lift on Red's cam is extremely narrow. (There, I tried not to call it small! LOL). If you compare it to something like the commonly-used HOTCAM, you'd see about 20 degrees difference in adv closing events vs only 5-degrees in the .050 events. Red's chosen cam will simply hold more compression.
Running the figures on the DCR show the hotcam displaying the same 11:1 compression as Voodoo cam (using the 64cc head scenario). With the hotcam, DCR is 8.6. With the Voodoo cam, it's 9.3! Because the voodoo cam gets closed 12 degrees SOONER, it generates almost 3/4 of a point more compression! That's not small potatoes people.
It's not until people really start to look at the actual cam events that they can understand how to compare cams. Personally, I don't believe a "known build" has to be used to accomplish Red's goals. I just think some common sense has to be applied.
Instead of comparing SCR to SCR and thinking "Well, if I lower my compression to only 10:1 vs 11:1, my car's going to suck. Dude, it's not! You've picked a cam with a lower lift and shorter duration. It's operating range is 1000-5500 rpms. That's where it's power will be. Considering you're going to use a TPI, that's PERFECT! And, because you chose that cam, torque is going to leave your nuts and the last stoplight.
Real compression will be just as high as the person running an 10.75:1 motor. Kapish?
Last edited by GREGGPENN; Feb 10, 2010 at 12:38 PM. Reason: Had compression's reversed, corrected it
Why not 7/10th...you might ask. Because I also believe the reverse cooling of an LTx motor makes the heads effectively run cooler. As such, they can tolerate 1/4 to 1/2 more point of compression IMO.
So, go on PLRX, raise your compression to 12.1:1. You'll be fine! (That's exactly what your trying to post in this thread you know!)
This issue has been kicked around for so many years and with so many differing views and recommendations that, for me, it all boils down to whose advice to heed.
I'm sure that many of you have read about this issue as much as I have. I've concluded it's all over the map, covering both ends of the spectrum and everything in between. Many of those who post on this offer lengthy explanations supporting their position and are absolutely convinced they're right. Then, along comes other guys who have differing views and are equally convinced they're right.
At one point I simply said "Enough's enough".
Essentially, what I did was put my confidence in the GM engineers; what they came up with in designing the engine. I have confidence that they already did the necessary homework on temperatures, gasoline quality, redline, etc. That eliminated a lot of the suppositions, variables and assumptions so often made when this issue is discussed.
As an example, I took a look at the LT4's CR and the factory installed cam for that engine. I crunched the numbers (hence the science) and used the results as a ball-park.
To me, there's no need to re-invent the wheel and it was time to move on. Yet, you guys are free to have at it, LOL.
Jake
Mike
I think Red wants a concrete answer about HIS setup, not someone else's, or what GM did.
Mike
Little steep on cost, not to mention it doesnt have aluminum heads, balancer or flexplate...and Id still have to buy the valve covers I want, intake stuff, headers...Id have 5K in the engine alone.
