How much compression is too much, for 93 octane.
Unless you (and he) have the EXACT same setup SANS the cam, your recommendation/assurance to PLRX would be -- as risky as PLRX telling Red that 11:1 would be fine in his motor.
It's NOT apples to apples.
Look how hesitant Brian was to say yes/no and he's the one building the most engines in this thread, right? Did he refer to SCR or DCR?
I might as well
vs try to make a point here!
It's NOT that simple but, yes, using a "big" cam lowers DCR.
The "secret", if there is one, is to learn/understand dynamic compression, get your quench right, get your tune right, adjust cooling temps/system (if necessary)*, and remove any sharp edges on the pistons (or cchambers) that could cause "hotspots" -- leading to pre-ignition.
Why should I care about a L98?
Looks like you have all the answers, give the guy your input, you take the credit and glory.
..WW
1) Explanation how to use DCR guidelines to stay safe.
2) Being told nothing is scientific -- to ape GM.
3) Other's saying 11:1 is doable w/o details on how/why.
4) Other's saying to change course and do a known combo
5) Bail on the CF and get advice from his builder
The pissing contest to which you refer was a simple challenge on why 11:1 was not a safe bet -- with Red's cam. Would you rather see suggestions w/o debate? Answers w/o reasons?
As someone who's gone thru this, solid reasoning is good to see/have. Without that, it's not worth the money/risk to alter a motor. I empathize with Red's concern and I certainly noticed his lack of participation for the past couple of days. From my perspective, it started when people said he should bail on his current path and go with a "known build". (That there was no science to figure this out). IOW, there was little effort aimed at helping him get his current parts to work -- with explanation of why/how.
Are you surprised at the result?
FWIW: I hope the points made here give Red reason to talk to a builder, learn more, and return with add'l questions to help him feel confortable about his course of action.
..WW1) Explanation how to use DCR guidelines to stay safe.
2) Being told 11:1 is doable w/o details linked to his cam/setup.
3) Being told nothing is scientific -- to ape GM.
More debate on items 1 or 2 would have improved this thread (IMO), but no one else is willing/able to (earnestly) participate**. As someone who's gone thru this, solid reasoning is essential. Without that, it's not worth the money/risk to alter a motor. (It was obvious Red feels that way.)
FWIW: I hope the points made here give Red reason to talk to a builder, learn more about what makes a given combo work, and return with add'l questions to help him feel confortable about his course of action. If you're not going to build a known combo, it's wise to gain the insight necessary to deal with the alternate path you decide to go on.
** Thought: As time goes by, this (C4) forum is bound to dwindle to look more/more like C3, C2, etc... IOW, fewer people will participate as newer models arrive to spark interest. How much of that do you think is happening now?
http://forums.corvetteforum.com/c4-t...-w-photos.html
It is just a 383 small block. Ain't no big thing. It's been done to death.
I dont want detonation worries, and I want to run no more than 93 octane.
Scat-1-40755
Forged crank, forged pistons, forged 6" rods, etc etc...383stroker.
Use will be street/cruiser, occasional strip use.
My original plans were 10.5:1...but I cant seem to find a kit that has the features I want that goes down that low, or doesnt go too low.
Im willing to use hyperutectic pistons in a kit...but would prefer forged.
) if this type of stuff has been mentioned already:.....My personal 93 octane pump-gas engines (and customers engines) commonly get set-up with 10.7(on the low end)....and up to 11.7 to one compression ratio's on the upper end....but more often than not, what ends up being the supreme factor for the detonation threshold is what EXACT cam specs will be run in the engine, and how that particular cam bleeds off cylinder pressure as a result.....We have found that as long as were around the 200-205 cranking compression range, on a basic (nothing wild technology wise) assembly, were more than ok with no detonation of any kind......and can push things as high as 215-220ish (cranking compression) if many (or ALL) of the detonation threshold raising practices have been implemented for that particular engine set-up.....For example: on my current Forged 388 LT-X stroker.....were at an honest 11.7 to one....and I have the quench distance set @ .35 thou... the piston's crowns & skirts have been friction & thermal coated... my combustion chambers have been CNC machined and contoured to have no real sharp edges...spark plugs are the perfect heat range for the set-up... and their ground-straps have been rounded (IE: nitrous plug prepped) to remove any sharp edges.........With a VERY mild (custom grind) street cam in the mid-high 220's @ 50, on a 112 LSA, & just under .600 lift....I'm cranking 216-218 PSI cranking compression...and it's showing ZERO signs of detonation of any kind.....No knock retard.....and the plugs look perfect when studied under a magnified scope......The previous (larger) cam that I had in was in the 240's @ 50 on a 110 LSA with about the same .600 ish lift, and the cranking compression was down in the 205 range so we were even further away from problems.......PS: I also have some buddies that are in the honest 12.5 -12-7 to 1 range with super large 280's @ 50 roller cams running 93 octane pump gas with zero detonation issues.... so my point is that there's never really just one answer for compression ratio.....if you not interested in really maximizing the compression set-up for 93 octane , just use one of the tried and true set-ups that most go with in the 10.5-11.0 compression range , and pick a cam in the 220's to 230's @ 50, on decently wide lobe centers (IE: 110-112 LSA's are great for the street on FI engines) and you'll be more than fine.........good luck with your engine.......JoeLast edited by 95NOSvette; Feb 11, 2010 at 06:49 PM.
From all the source I "polled" on this subject (mentioned earlier in this thread), that's consistent with their recomendation. As such, I would agree with that.
With the smaller .450" lift/213 duration voodoo cam selected by Red, cranking pressure WILL go up because of the reduction in actual duration (seat-to-seat). Because of the increase cranking pressure, the SCR should be lowered to compensate. In terms of static compression, 10:1 is the boundary I think Red should stay under -- if he really wants to be certain of flawless operation.
95NOSVette, please say whether you agree with my lower 10:1 SCR recommendation using the Voodoo cam specified. Whether it's yes or no, that should be helpful to Red (and other readers).
FWIW, Red will use 1.6 (vs 1.5) rockers in his application. Since we all know bigger rockers make the cam operate with a more aggressive profile w/o letting add'l cranking pressure bleed off (like a higher lift/longer duration cam would), those new effective figures won't raise the recommended compression range/limit.
Thanks Ron! I probably get too technical and wordy (even though I hope people want to learn). But, your short/simple answer is perfect.
One thing people who haven't built a 383 might not realize is compression goes up because of the longer stroke.
60103?
Advertised Duration (Int/Exh): 268/276
Duration @ .050 (Int/Exh): 227/233
Gross Valve Lift (Int/Exh): .489/.504
LSA/ICL: 110/106
Valve Lash (Int/Exh): Hyd/Hyd
RPM Range: 1800-6200
If you don't consider a head that flows well above 250cfm (for a 383), you might just be better off selling that cam and buying a "bigger" one. (Of course, if you do that, you could do that higher compression thing!)
Edit: I was typing this while you posted above. I'll post back later tonight on your cam request. In the mean time, reread what 95NOSVette posted on cam specs.
