need help with L98 vette!!!
Old Feb 8, 2010 | 04:26 PM
crAzy's Avatar
crAzy
Default need help with L98 vette!!!
my buddies 91 vette is having some problems and can't figure out, hope ya'll can help. he was driving it last night and it just died on him. he replaced the module under the cap and put some wires in the wrong spot. he limped it here to my house and i got the wires put on correctly, and yes i'm sure they are correct, 1,8,4,3,6,5,7,2. so after i redid the wiring we took it for a spin and as soon as you get into the throttle it dies. we limped it home again and restarted it. it ran fine and even revved up to like 3500 rpm, but at WOT it dies. after playing with it a min. and trying some other things with the car running it died. now that its hot it turns over and WANTS to start but won't. it is getting fire and the fuel rail is reading 40 psi. i was thinking of just redoing the entire ignition system. any and all help would be appreciated because i don't think a set of wires and plugs is gonna do it.
Old Feb 8, 2010 | 04:29 PM
ch@0s's Avatar
ch@0s
ck your fuel pressure when hot, when cold and at WOT sounds like it's fuel related. Fuel pumps can stop working once they get hot if bad. Also ck the vac line going to the FPR if it has gas in it it needs a regulator.
Good luck
Old Feb 8, 2010 | 04:39 PM
crAzy's Avatar
crAzy
the fuel pressure test was done with the car warm. the schrader valve on the fuel rail is AFTER the FPR. if the FPR was out wouldn't i have a low reading on the fuel line pressure? is there a way to test the FPR?
Old Feb 8, 2010 | 05:00 PM
bill mcdonald's Avatar
bill mcdonald
I would pull the dist cap and make sure everything underneath was put back right.
Test the coil... although I think they just die. Mine did and left me stranded.
and then back to the wires... triple check em, and I would throw a timming light on it. make sure he didnt move the dist.
How far did he drive with the wires wrong. how wrong were they?
I would probably pull some plugs as well.
Kind of dont really know where to go but it seems by the order of events it would be ingition related.
Old Feb 8, 2010 | 05:11 PM
crAzy's Avatar
crAzy
i just pulled the cap and rotor off. the tabs the rotor screws into has a lot of play in it. is the rotor not supposed to have ANY play or what. thnx for the help
Old Feb 9, 2010 | 05:39 AM
kenmohr's Avatar
kenmohr
check your fuel pressure at wot. The volume of fuel may not be there. I agree it sounds fuel related. Tape a pressure gauge to the windshield the go for a run.
Old Feb 9, 2010 | 09:07 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Why did he replace module under cap, did he loose spark ??
Ohm test those Multec injectors, cold, and if it starts again, hot.
Old Feb 9, 2010 | 10:11 AM
Jimbo 89's Avatar
Jimbo 89
If you have the stock injectors, it's only a matter of time before they go bad.
The ethanol in the fuel eats them up.
Read the 4th sticky down on tech/performance. I got my injectors from Jon at FICINJECTORS. Good guy, and great price.
Whatever you do, DO NOT replace them with Multecs.
Old Feb 9, 2010 | 08:09 PM
666Vette91's Avatar
666Vette91
Is your catalytic converter clogged, may want to check that part out
Old Feb 9, 2010 | 08:31 PM
Calderone's Avatar
Calderone
Jon at FIC its one of the best things that can ever happen to your car !!!
Old Feb 9, 2010 | 10:25 PM
Muffin's Avatar
Muffin
Did it set any codes? If so what are they? If you have spark and fuel pressure my first guess would be something in the injection system.
Old Feb 10, 2010 | 08:24 PM
l98tpi's Avatar
l98tpi
Max G’s
Sounds like fuel to me also, but if that doesn't resolve the issue, maybe try to look at the oil pressure switch.
Old Feb 10, 2010 | 08:36 PM
crAzy's Avatar
crAzy
It only starts when cold, but once the car is warmed up and we turn it off we are unable to start the car again.
Old Feb 10, 2010 | 08:56 PM
ex-x-fire's Avatar
ex-x-fire
OK, when it dies- check for spark, at the end of the plug wire. Try spraying carb cleaner into the throttle to see if it starts alittle. May need a noid light to test injector pulse, use a long screwdriver touching the injector & put the handle to your ear, should hear them clicking when cranking. Ohm the injectors when hot. Could have a senser affected by heat, may need to have it scanned or try unpugging one at a time to see if it fires at all.
Old Feb 22, 2010 | 01:17 PM
Jimbo 89's Avatar
Jimbo 89
Originally Posted by crazy03z06
it only starts when cold, open loop but once the car is warmed up [GOES INTO CLOSED LOOP[/B] and we turn it off we are unable to start the car again.
this is very typical of bad injectors!!!
Old Feb 22, 2010 | 03:37 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Don't spray anything in the intake unless it's gasoline!!!!! and just a little.
Old Feb 22, 2010 | 04:41 PM
RC000E's Avatar
RC000E
How about don't spray anything in the intake period. It's not a carburated car, and troubleshooting fuel injection doesn't involve those methods. Spraying in volatile fluids only to have it stumble and tumble doesn't tell you anything that can't be determined by proper troubleshooting methods.
To need help with L98 vette!!!
Old Feb 22, 2010 | 05:51 PM
rlane5's Avatar
rlane5
Check the coil with a meter, it sounds like it's in the ignition
Old Feb 22, 2010 | 09:17 PM
SteelBlue91's Avatar
SteelBlue91
Exact same thing was happening to my 91, had 2 bad injectors on the driver's side. Not saying it couldn't be ignition, but it is so easy to check the coils on the injectors.
Old Feb 23, 2010 | 10:41 PM
RiceBurnerZ07's Avatar
RiceBurnerZ07
Test the ECM
